New GT suddenly would not respond to throttle above 20 mph
mwillems
mwillems
Ottawa
2026 Mustang GT convertible, standard
I had the speed limiter set on even lower speed. You can set the speed limiter manually on a specific speed. I think mine was on 15mph.
Mmm. But the setting was on "Warn only", so even if I had accidentally set it to a low speed, it should not have stopped throttle response - do I have that right?
ZXMustang
tooner
I think there have been a rash of faulty gas pedal assemblies. I had two DH owners I worked with have this as a problem and the dealer replaced the gas pedal.
mwillems
mwillems
Ottawa
Shiiiii.. That could totally be it.
True. Except I checked and the option was set to "Warning only", so even if I had accidentally set it to 35 km/h AND accidentally pressed the button, it still should not have stopped the throttle from doing anything - right? I await what Ford says...!
GrabThatBlue
Between Canada and Europe
You are talking about a different setting. (Speed warning).
I'm talking about a speed limiter. Not a warning option. The button is on your steering wheel, left side.
mwillems
mwillems
Ottawa
Yup, I know that button - and avoid it like the plague, haha!
The dealer called - they did find a "low voltage" alarm, which is weird because it's a new car with 1,000 km on it, and I've been driving distances with it, and it wasn't't left outside with lights on - nothing like that. So they're keeping it overnight for more testing.
mwillems
mwillems
Ottawa
Ah but the manual says that even if I did set and active the speed listed, you can exceed the limit if needed. And I was unable to exceed the limit: even pushing down totally on the gas pedal, speed remained limited to just over 30 km/h.
From the manual (boldfaced emphasis mine):
HOW DOES THE SPEED LIMITER WORK
The system allows you to set a speed to which your vehicle becomes limited. The set speed sets the effective maximum speed of your vehicle. You can temporarily exceed the set speed if required, for example to overtake.
The controls are on the steering wheel.
GrabThatBlue
If you have it again, try it. That's the only way to figure out what it is.
mwillems
mwillems
Ottawa
Dealer is keeping it overnight to do more testing and test runs, so we'll see tomorrow. They did see a low voltage warning, so indeed there may be something going on.
And yesh, manual says this, and believe me, I certainly "pressed firmly on the accelarator"!!
INTENTIONALLY EXCEEDING THE SET SPEED LIMIT
Firmly press the accelerator to temporarily turn the system off. The system reactivates once your vehicle speed drops below the set speed.
