Need some wheel/tire size advice
P2
I'm looking to upgrade my current setup which is the silver wheels that come on the GT Premium (see picture of my car to the left) I'm looking to get a little bit wider stance. I'm looking at either a 19x9.5 or 19x10.5 wheel with a square setup, not a staggered setup. Which one would fit better and not have to worry about any issues like rubbing. What would be the best over all tire size? I was thinking 275 all the way around or is that too big would 265 be better. Keep in mind that I don't want to make the car look weird but do want a more aggressive stance without changing the handling or drive characteristics. Your advice would be greatly appreciated.
agreywolfe
Oklahoma
275/40 is what ford puts on the pp 19x9.5" rim, for the 10.5 nitto says a 295/35 is recommended fit for that.
P2
P2
I was originally looking at a 19x10.5 but was told that would be too big and would cause issues. Can anyone confirm that? I was also looking at a 275/35/19 or would the 275/40/19 be better?
Dave2013M3
El Segundo,Ca
If you want to go squared run 19X10 ET35 on all 4 corners with a 285/35/19 tire.
P2
P2
The Wheels I'm looking at don't come in 10... they come in 10.5 (which is why I'm looking at 19x9.5) and putting a 285 on it might cause some fitment issues.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
10.5 up front is a bit to wide we recommend a 10 up front or 9.5 square
Dave2013M3
El Segundo,Ca
Which wheels, offsets are going to be a big part of the equation.
Dave2013M3
El Segundo,Ca
The PP on the Mustang is the last benchmark I would look at. The PP cars are so undertired. You have a 3900lb car with a 56/44 weight distribution and only a 9" wide front wheel with only a 255 tire.
To the OP, rethink your wheel choice I wouldn't go below a 10"wide wheel for the front. The Mustang needs as much wheel and tire as possible on the front of the car.
agreywolfe
Oklahoma
Op was asking about if a 275 size tire would fit on a 9.5 rim with any issues. The stock pp 9.5 rim with a 275 tire on it seems like a great benchmark for comparison.
Dave2013M3
El Segundo,Ca
No he is moving on to a different wheel.
[I'm looking at either a 19x9.5 or 19x10.5 wheel with a square setup, not a staggered setup]
agreywolfe
Oklahoma
You should re-read what they said.
Here they are asking about a 19x9.5 setup, the 2024 Mustang GT Performance Pack comes with a 19x9.5 rear wheel.
Here they are asking if a 275 is a good fit for the wheels they are considering. The 2024 Mustang GT Performance Pack comes with a 275 rear tire.
Here I am saying that the 2024 Mustang GT Performance Pack has the exact wheel/tire combination he is asking about to confirm that the wheel and tire size they were asking about do fit, then suggest what a second tire manufacturer suggest for the secondary wheel size they requested.
Dave2013M3
El Segundo,Ca
I was responding to this.
