- Joined
- Sep 22, 2022
- Threads
- 78
- Messages
- 2,683
- Reaction score
- 4,071
- Location
- Cave Creek, Arizona
- Website
- roketgamer.dev
- Vehicle(s)
- 2024 Ford Mustang Dark Horse
- Thread starter
- #1
...or a 2025 GT Performance Pack with Magneride, Active Exhaust, and CoPilot 360+ would work too
i'm trying to see if it would be possible to activate the exhaust and suspension mode buttons from the GTD by changing one thing in the SCCM's as-built data. in the SCCM at address 724-02-01, the third, fourth, and fifth digit in the values should be a "346",
xx34-6xxx-xxXX. based on inspecting the GTD as-built, they have this value as "446" instead. trying it on mine made the entire left button cluster do nothing until i changed it back, but that may be because the 2024 job 1 SCCM didn't have the programming to handle it yet. note: if your factory value reads xx74-6xxx-xxXX, that means your steering wheel buttons likely lack the follow distance adjustment and speed limiter enable buttons, so you will not be able to help with thisSponsored
