I checked for magnets…
Achlys
KC Metro
The Ford dealership 18 year employee “his words” didn’t know what a pin-plate balance is. So I went to Costco because I know the crew, I use to manage the shop. From the factory every wheel was off by .50 ounce, which is why I felt the front end was off. Then the tech calls me over and shows me a wheel that’s bent! 5K miles and a bent wheel, not what I was expecting. So in your opinion, I’d it better to get a new wheel or change them all?
If the wheel was actually bent by you (not in shipping or other mishap), then you probably need stronger wheels. Are they factory wheels or ? I must confess, not sure I've heard the term "pin plate balance"... I assume it is to balance lug centric as opposed to hub centric.
Achlys
Achlys
KC Metro
About 5100 miles. Took it on a trip to Texas in June, many road issues. That’s my guess for the cause. Really surprised that a OEM wheel would be affected by a hit I should remember. I’m old, so there’s that.
Pin-plate balance is coned on the back side of the wheel with pins that mimic stud/nut connection to the balancer on the front of the wheel. This in turn creates an accurate connection to the balancer, giving a more accurate balance.
mthx
Quebec
DH 2026
Honestly, if the wheel is only slightly bent and hasn't cracked, I'd at least get a quote from a reputable wheel repair shop before buying a new one. There are many places that specialize in straightening wheels, and they can often restore them to factory specs for much less than the cost of a replacement. I'd only replace it if it's cracked, severely bent, or can't be brought back within spec. It's definitely worth checking before spending the money on a new wheel.
D/\rK•650
2025 Mustang DarkHorse
If it's bent a certain way it can't be repaired. One of my 370z wheels was bent and when I asked if it could be repaired because it was at a wheel resurfacing place, they said no because it was bent "out of round",? I want to say. It wasn't severe but not repairable.
Achlys
Achlys
KC Metro
mthx
Good point 👍
What I’ve seen is when the rim/ bead area is bent, is cutting out the damaged area and then repairing. I know of a business that does wheel repair, it’s worth a shot.
SSuperDave
Friendswood TX
Well, I've been in the dealership service business for 48 years and never heard of a pin plate balance either. After reading a bit further down, I see that you are actually talking about a lug centric balance. Ya learn something new every day.
Achlys
Achlys
KC Metro
For reference.
Lug centric, we have always referenced as pin plate.
S650 Mustang I checked for magnets… IMG_3066
glenng6
Easton, PA
Sorry, I’m new wheel all day long. There will always be another pothole you don't see or can't avoid. It's not like it's cosmetic, and what will happen when you hit the next government-patched job that failed? YMMV! Glenn
