HP Darkhorse Wheels installed on Base Darkhorse
MyDarkhorse79
San Antonio
24 Mustang Darkhorse
I just installed a set of HP darkhorse wheels on my Non HP darkhorse, the fronts wheel lug nuts are more recessed than the rear, is that normal?! And the Front wheels look like they stick out more than the rear, I'm thinking rear spacers to match the fronts. Anyone here with that issue?
S650 Mustang HP Darkhorse Wheels installed on Base Darkhorse 20240218_224810
S650 Mustang HP Darkhorse Wheels installed on Base Darkhorse 20240218_224600
radar
Melbourne AUSTRALIA
2017 GT Convertible 5 Litre V8
Are they different wheels?
Same style?
What are the spec differences?
Look good
lostwon
Way West of the Pecos
2022 EcoBoost A10; 2023 SCCA SD Regn DS Champ
Which tires did you use?
MyDarkhorse79
San Antonio
Same style?
Look good
I think these wheels are .5 wider for front and rear, they were on a darkorse with handling package, my ocd is messing with me, the fronts stick out a lil bit, the rears not so much, wondering if spacers for rear to match fronts is a good idea or not?!
cosmo73
Berks County, PA
24 GT, 20 A5
Can you take a better picture down the long side of the car to see what you are describing?
Saburak
France
DH BLK / 10-Speed / RECARO
there may be a difference in height and geometry with the HP pack 🧐
Upacurb
Up a curb at cars and coffee
If it helps...on the GT350 and GT350R - they each have different front hubs I believe and he length of the studs is different - (I believe the main difference is the length of the studs)
Basically you cant just bolt the GT350R wheels onto a base GT350 without changing some things-
I wouldnt be surprised if there was the same issue here- which is why the wheels are not fitting correctly
Hopefully this helps get you pointed in the right direction
horned-toad
DC Metro
2012 Audi S5
bad photos don't help but doesn't seem too far off. But I would double-check to make sure you put the front wheels on the front and didn't mess that up.
REV745DH24
Sending my picture of the front wheels! Hope that’ll help!
S650 Mustang HP Darkhorse Wheels installed on Base Darkhorse IMG_2688
S650 Mustang HP Darkhorse Wheels installed on Base Darkhorse IMG_2687
REV745DH24
Twizzty
Central Florida
2021 Camaro 1SS 1LE
Looks like the OP needs the front fender extensions to cover the HP wheels. @REV745DH24 has them but I don't see them on the OP's pics.
