Yamazuki
- Joined
- May 14, 2025
- Threads
- 5
- Messages
- 480
- Reaction score
- 770
- Location
- North Dakota, USA
- Vehicle(s)
- 2024 Dark Horse, 2013 Ford Raptor, 2004 F150
- Thread starter
- #1
I know there's been some talk about Approach Lighting in the main spreadsheet thread, but didn't see where anyone had actually gotten it to work.
If you're unfamiliar with Approach Lighting, it is simply the vehicle turning on the Welcome Lighting when the key fob has been away from the vehicle and then comes near it again. There will no longer be a need to unlock the doors with either the key fob or via the door handle to get the welcome lighting to display.
Disclaimer:
As with anything Forscan related and the multitude of different trim levels and options available on these cars, YMMV.
This is what worked for me on my 2024 Dark Horse 600A with handling package after I had previously enabled welcome lighting by following the instructions in a popular YouTube video.
My car had neither welcome lighting, nor approach lighting, enabled when I picked it up at the dealer.
APIM 7DO-09-01 xxx* xxxx xx--
IPC 720-01-01 xxxx xxxx *x--
For both of these addresses, you'll want to compare your current value with the spreadsheet and select the new value accordingly.
You want to keep all of the functions the same (enabled or disabled), except that ADCF needs to be enabled.
BCM 726-18-01 x*x* x*x* x*--
BCM 726-27-01 x*xx xxxx xx--
BCM 726-45-01 xxxx xxxx x*--
Change all the *'s to 1
Follow forscan's instructions and cycle the key after each module is written.
Once complete, you should be able to exit the vehicle, lock the doors, and walk 15 to 20ft away from it.
When you walk back towards the vehicle, the welcome lighting should come on once the key fob is detected.
Hope this works for others here on the forum!!
Disclaimer:
