Gears not showing
MagneticMartian
Does anyone know how to make it show what gear it is in on the instrument cluster? (10spd) no matter what mode I use it just shows me the cruise control and lane keeping icon instead of showing me the gears unless I use the paddle shifters.
MagneticMartian
Has anyone figured this out? Does anyone see gears on their dash when not in manual mode?
ā‰ˆ39N
I skimmed through the Owner manual just now. See page 177.
When in Automatic/Drive mode, "The instrument cluster displays the current position [PRNDM]."
When in Manual mode, "The instrument cluster displays the current gear."
I agree. It'd be nice to see the gears change and confirm specific gear when in Drive mode.
Deleted member 60295
Guest
I was wondering the same thing , I liked that you could see what gear you were in all the time . My Mach showed the gear as well . Maybe Ford will do a update and add that option šŸ¤·šŸ» maybe šŸ¤”
CarGuyBill
Homer, Georgia
24 Dark Horse Blue Ember
On the F-150 Ranger etc. you can press the + on the shifter when sitting still or moving + and it will show what gear it is in until it is restarted. I would guess you have padel shifters so that will most likely not work. My Explorer ST does not show the gear unless you hit the paddle shifter and that puts it into a temp manual mode.
CarGuyBill
Homer, Georgia
Best thing to do is Call the Ford customer service line and let them know that is how things get added over time.
WavnAtCha
Wesley Chapel, FL
2024 Ford Mustang GT Premium Convertible
I just found this. I have not verified if it works.
If the gear isn't showing on the dashboard of a 2024 Ford Mustang, you can try resetting the SYNC screen to factory settings:
  1. Select Settings or the Home icon
  2. Press Reset
  3. Select Factory Reset
  4. Follow the on-screen prompts to complete the reset
jboogie1289
Friendswood Texas, 77546
Search this on the Forum. It only works if you use the FORScan Tool and add it to your gauge cluster, along with some other added items. @roadpilot and @rugedraw can answer more questions about this. I’ve already contacted Ford (EAP participant) about the addition of this since I (we) who owned the S550’s had that option available to us.
This!
I had to wait for the .62 FORSCAN version to be able to update my Dark Horse - May, '24 build. I was able to easily implement continuous gear display with it.
Yup. Already documented here. Not going to do it again. Search. šŸ˜€
