Forscan Stop/Start
So0_NaSTy
NY
2024 Ford Mustang GT Premium
Hello everyone. For those of you with the job 2 mustang with the stop start, did anyone manage to figure out how to disable stop start via forscan?
W/o forscan: Select sport mode during preflight check
So0_NaSTy
So0_NaSTy
NY
Have to do that everytime. I’m curious if with forscan you can fully disable it.
mikiet60
sterling va
2024 gt
I was told by the mechanic at Koonz Ford Sterling that with four scan, you can change that and just about everything else as I ordered a base model GT 300 a and I put aftermarket stereo system in it, and of course, the welcome thump has been amplified through the subwoofers And worst of all the pumped in exhaust noise through the sound system has been amplified and I’m trying to find a way to turn it off so he told me about foreskin being the result to fix this
At this point in time, it is my understanding, the default emission setting is required during startup and is unable to be modified. There are various ‘faults’ and conditions that will prevent it from functioning, even when enabled (in fact there is an active/paused recall for the very behavior) but at this point there is not a forscan setting that will disable it for startup.
