DRL kit to change the color?
hayden5.0
2024 mustang gt premium
I’ve evening looking at picking up some rbg headlights as I want to be about to run red or something sometimes but they are $1000. Is there a kit where I can just swap out the Drl?
Bear376
Stillwater, OK
I doubt it. Light colors are strictly regulated and they can fine you and make you replace the lights back to stock. At worse, they can make you take it off the road or confiscate the car. Check your laws before spending any money. I had my 2013 rigged like Knight Rider, but I could only use them in parades or shows.
hayden5.0
hayden5.0
Yeah mine would only be pictures and maybe rollers. I just want a different color without hella money being spent
just so you know, in order to swap out the DRL boards, you will need to essentially bake your headlights until the adhesive softens, peel them apart and remove the old adhesive, replace the boards, then re-apply new adhesive. it's very labor intensive. i recommend just getting the ones from https://autoaddictusa.com/collections/23-24-mustang-collection. but if you really, really want to do all that yourself, here's some that i found. https://www.autoledtech.com/products/2024-ford-mustang-rgbw-flow-series-led-drl-boards
synster
Brooklyn Park, Minnesota
Did you install the Auto Addict headlights on your car? Were you happy with the quality and the performace of them? Thanks in advance.
i have the stock headlights, sorry
Yamazuki
North Dakota, USA
I've done a few headlight mods, installing either HID or LED projectors, but they were mostly on older F150 or F250's. With the cost of a new headlight assy for the S650, I'm not so sure I'd be overly excited to attempt it. Simply too much to go wrong. I'd rather spend the money on the aftermarket assembly's.
