Dashboard and display rattle - FIXED!
eriklieders
NRW
Mustang s650 GT Performance
Hi! I had a nasty noise coming from the front all the time. I removed the display and found that some of the clips had a few millimeters of play. After taping them up and applying gun oil, I installed the monitor back and now the car is quiet.
Mustang 2024 s650 GT Performance
Frogdog1
Dixie
Congratulations! That helps my Ford confidence.....
eriklieders
eriklieders
NRW
In the heat the plastic becomes soft and the back cover of the display starts to make noise when driving. Carefully smeared it with glue and now there is silence.
eriklieders
eriklieders
NRW
Yes, I bent the back cover back as far as possible and smeared it with superglue. Not the best option, but it worked for me. Ideally, you need to completely remove the display, disassemble it and glue it from the inside, but I had neither the time nor the desire.
CMcA
PA
can you describe how to remove the monitor so that I can access the clips to tape and lube them. Thanks for the info. I have the rattle when sun is hitting the dash and the a/c is on.
eriklieders
eriklieders
NRW
CMcA
PA
thank you eriklieders. straightforward
eriklieders
eriklieders
NRW
You're welcome. I'm just tired of 99% of people not being able to find a solution to their problems on a thematic forum. It must be fixed!
