Custom profiles just disappeared
Neco
Spain
S650DH
I wasn't sure where to post this, and if I should just take it as normal behaviour, or something is actually wrong.
I recently bought a MY26 DH, and I'm sorry to say that almost didn't use it yet. Too much workload, and I own some other cars as daily. The point is that I still don't know it very well, but this glitch seems really weird, or maybe I'm just missing something. Have any of you seen the custom profiles configuration "button" just disappear from the screen? Or, being more precise not even appearing. Just gone. Only four buttons available when pushing the "my Mustang" button in the dash.
I turned contact off in a traffic light, wait as long as I could, turn it on again, and nothing, still four buttons. I parked the car for a while, like 15/20 minutes, turn it on, and voila! customisation button available again.
Are there ghost in my car, of this is the quality I could expect from SYNC infotainment system? I have never ever had such issue with any car before.
DarkHorsePremium
CA, Bay Area
I was in my sync4 yesterday changing settings and I could swear I saw a Profiles option. Like you, I haven't bothered with them. I'm the driver 95% of the time. My wife wouldn't use them. She'd only be concerned with seat memory. I believe there are only three slots. Can you confirm that you are talking about user profiles and not about favorites? I'll look today.
Neco
Spain
S650DH
I'm talking about the menu with 5 buttons you get when you push "my Mustang" button. With the track apps, aux indicators, profile configuration, my colour, and Speedo design selection. The profile configuration button just didn't show up, only 4 buttons available...
I've just tried again, and here they are all them, as always. Weird thing...
I could selec the custom profile with the steering wheel buttons, but with this silly way of doing things, I couldn't select the profile that I wanted, because you have to do that in the screen, using the missing button...
S650 Mustang Custom profiles just disappeared IMG_20260416_190238
Neco
Spain
S650DH
By the way, I use the custom profile for just one single reason, because thats the way to avoid the start-stop nightmare. But as I have to select the custom profile anyway anytime I get into the car... It is also pointless, it's easier to just turn it off manually (just one click, switching from normal to custom needs two clicks...).
Ford... You're turning simple things into very complicated ones.
DarkHorsePremium
CA, Bay Area
Thanks @Neco
I'm going to look more closely at this today. Fortunately I have a '26 DHP without start stop. I decided a long time ago that I wouldn't consider a car with this technology. The start feature at a signal for example is not fast enough for me. Not to mention the wear and tear this would put on a starter motor. Glad yours seems to be working now.
Yamazuki
North Dakota, USA
I ran into this on my '24 Dark Horse just yesterday! Looked all over for the Custom Profiles option, knowing it should be there somewhere. Could not locate it anywhere, despite still being able to select my last saved custom profile with the steering wheel buttons.
Soft reset on Sync did the trick.
Press and hold both the right arrow and volume down buttons on the steering wheel.
D/\rK•650
2025 Mustang DarkHorse
Yes this kind of thing does happen from time to time. You can try a reset with righ hand d pad button and volume down. Hold these down till it resets. That should help.
Neco
Spain
S650DH
That is so crazy...
I could understand it if this was a new model just launched, as just an early little software glitch which could happen and would be solved on a later update. But that's not the case. What makes me think that nobody will take of it, as it's just the way it is.
Another good reason to hate the "virtual" software buttons (I already hate them quite a little bit).
GrabThatBlue
Between Canada and Europe
I had a different issue with custom profiles.
All custom profiles had the same dashboard style and if I changed the style, it changes them for every drive mode. It did this for 2 days and then it resetted.
npole
Italy
Mustang Dark Horse 2024
ForScan is your friend (enabling to remember the last mode used, so you don't have to select custom at every start).
Almost wonder if a soc issue.
Neco
Spain
S650DH
Thanks mate.
It's already writed on my TODO's list, just didn't have time yet to get my hands on it. I'm new on Ford, and all dongles and software I already own are for VAG cars. I still didn't even buy a Forscan compatible dongle. Currently looking at the OBDLINK MX+ (which looks good, but seems a little bit on the expensive side to me) or the VLINKER FS (pretty affordable, and doesn't seem to be that bad, or worst than the MX+).
I could call myself as "advance user" after more that 20 years using VAGCOM (now VCDS) and I don't mind at all paying for a good dongle, I know it's worth it, but I can't really see so much difference on performance for such big difference on price (50€ Vs 150€).
npole
Italy
