Custom mode partially working
Paul2020
Australia
2024 Mustang GT Atlas Blue
Anyone had an issue with Custom Mode where the dash/cluster display stays the same.
When I select Custom mode 1-2-3 etc. the exhaust & steering change as does the Mode number but the dash stays on the same display.
Eg if dash is showing Normal & I select custom mode 3 which has display set to Sport, dash/cluster stays on Normal. (as above exhaust /steering & mode number update)
I tried a factory reset & reset all the custom modes & recreated them, still didn't fix issue.
Thanks for any advice.
do you have a consistent dash display through the regular modes, I believe that’s a separate setting.
abz
CA
2023 Chevrolet Colorado, 2025 Mustang GT
you need to select (activate) custom mode using buttons on the steering wheel
if not in custom mode already, choosing on the touch screen only selects which will be activated the next time
Paul2020
Paul2020
Australia
I can change the display through settings. Just won’t change using Custom mode..
I’m selecting Custom on the steering wheel as well. It just won’t update the display. Mode / exhaust / steering all correct as per mode # just display wont change to fox body / calm etc.
Paul2020
Paul2020
Australia
I can change the display through normal cluster gauge settings..So can change that to Track, Sport etc..
