Creaking noise from suspension
ShaBoingBoing
New York
Infiniti G37
Anyone else having a creaking noise come form their suspension when going over bumps?
Crew4991
Any new car should not have creaking noises.
What kind of creak noise are you hearing? Like more of a squeaking creak (could be from rubber bushings ect.) or more of a door on a rusty hinge type of creak (suspension)?
Either way I would probably have a shop check it out and see what their analysis is, then take it to a Ford dealer for them to work on the car.
jexsk
Louisville
‘24 Mustang GT, ‘22 F-150 Lariat
Mine wasn’t really a creaking noise so much as a rattle but yeah, shock replaced under warranty. Sounds like a few others have had some similar issues.
Eligdo11
Mustang 2024 gt
I have been encountering a creaking/grinding noise as well with the 2024 premium. Would this be the same? I have it on video
ShaBoingBoing
ShaBoingBoing
New York
Infiniti G37
Yes that’s the exact same noise that I have. I’m used to hearing it in older cars but definitely wasn’t expecting it from a brand new mustang.
marcekb
Mine is like jexsk's. Not like the creaking in this video...
Ford Motor Company
Official Ford Account
Dearborn, MI
Ford Mustang
Hi there. Will you send us a PM with your VIN and dealership name/location? I can look into things on my end regarding these suspension creaking noises. To send a private message, just click on our username and select "Start Conversation".
ShaBoingBoing
ShaBoingBoing
New York
Infiniti G37
Ever find out what the cause was? I’m thinking bushings but not sure.
Eligdo11
Mustang 2024 gt
Not yet, planning on dealership to find out but waiting for the festive days to be over. I’ll post an update if they tell me anything
ShaBoingBoing
ShaBoingBoing
New York
Infiniti G37
Well I have an update although it may not be what you’re looking for. Turns out my dash cam install was messed up and the noise was my wire rubbing against the rear window. I removed it and the squeak is completely gone. Check if you can hear it from the outside. If it’s just the inside that you hear it from then it’s likely something minor like what I had. Hope that helps!
RJV15
Los Angeles
2022 Honda Civic Si
Does that happen while you are also turning the wheel?
It sounds like the springs are binding.
Ford Motor Company
Dearborn, MI
Ford Mustang
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Useless
Lexington, KY
2024 mustang dark horse
I am having the same issue in my DH. Also had to take it it for the shift linkage NVH. Replacing the linkage, hopefully they can get the creaking sorted as well. I do not believe they have even diagnosed that yet.
Dave2013M3
El Segundo,Ca
My 2020 does it as well over uneven dips going slow.
Massih408
San Jose
2015 Oxford White Mustang GT PP
This has been an issue on S550s as well. I have a creaking sound. I replaced my camber arm thinking this would be the fix. Am now looking at replacing the rear vertical link.
Some folks on the S550 side say this sound happens after you lower your car. Interesting this is an issue on the S650 as well
