Cobra Jet Manifold (for S650)
DarkHorseTT
Dark Horse
Your 7.7 run was on a cold day. 5 Celsius is 41 degrees Fahrenheit. You can't really compare that to a run at almost 80 degrees Fahrenheit.
Rob, do you mean Rob Shoemaker? He put it in writing that it makes less power than stock?
I mean, Boschma's car was tuned by Shoemaker. (Boschma is the maker of that adapter you installed with the two throttle bodies).
I have not seen anywhere that it loses power compared to stock.
robvas posted the dyno curves above. But click on the link and read the caption under the dyno curves.
please send link on Boschma’s tune that Rob made
screen of reply below
S650 Mustang Cobra Jet Manifold (for S650) IMG_7577
yes, stock cams
The Cobrajet is going to give you more usable RPM, not necessarily make more power at the stock RPM ranges. It may not make more power on stock cams (or if it does, just a tiny bit more near redline)
Do you have dyno charts of your car with both intakes?
2018 intake vs cobrajet but the idea is the same
S650 Mustang Cobra Jet Manifold (for S650) 016-cobra-jet-vs-2018-manifold.jpg
DarkHorseTT
Dark Horse
No, I have only stock manifold 540whp
Today installed Cobra and ran to highway for better numbers 🏃‍♂️
The stock intake performs really well, it’s not like the gen 1 coyotes, where we could slap a C.J. / mono and turn it up to 8500 rpm on E85 and see serious gains.
you really need to add cams to wake it up, but you’re basically gonna end up with “boost money” into a much slower N/A setup.
i would sell the intake and just run stock/E85 tune until you’re ready to add boost
DarkHorseTT
Dark Horse
No problem to buy R2 cams, the problem in Moscow is who will install them
but I think I will buy them as we have no choice
steedazach
Valdosta
S650
When we did the Boschma's Speed Shop dual throttle body, GSC cams, and cobra jet intake manifold, we increased around 50 hp and 11 ft-lb of tourque. This was also on a Lund tune.
DarkHorseTT
Dark Horse
if I install camshafts R2, can I use car for daily ride?
please send the link to buy cams and springs
steedazach
Valdosta
S650
steedazach
Valdosta
S650
Yes it can compromise ride quality without a good tune. My suggestion is to get a daily tune and a race tune you could maybe switch between. Installing the cams without a tune could result in rougher / more choppy idle, and reduced low end torque. Just important than if / when you do this, to get a custom tune. Better to buy once cry once.
