Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro)
I tried to put the EOS rock guards on my car.
The front side was easy and I really love the look. I only had to make the hole a little larger on the mud flaps to get the push pins through it. Stuck a knife in the hole and kept spinning on both sides until the hole got larger.
The rear ones are a pain in the ass. Not because of the mud guards but because if the tiny space between the rear wheels and the bolt and push pin.
I could not remove the push pin without breaking it out of there since it had an X for a screw driver, but you need a very short screw driver to get it between the wheels and the push pin. And I had a feeling it kept spinning as well.
So now I broke that son of a chicken out of there and now going to drive and find a push pin of that same size. I bought 2 push pins a few days ago but they are too large.
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250527_115221
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250527_130430
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250531_145408
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250531_145415
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250527_130352
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250531_145423
Okay, I went to the car part store and brought with me the broken push pin.
The only push pin they have that has almost the same size is the one I bought on the picture. I already knew it was too ahort, especially when there is now a whole plastic part in between but I still bought it to try anyways since they don't have any others this size.
and yep, it was too short.
And another problem is the bolt on top. Because of the rock guard I can't reach it with my ratchet. I need to buy a very tiny ratchet to get there.
Installing the rear rock guard is a pain in the ass man. I rather remove and install new my side mirrors like a few months ago.
I just hand tightened the bolt just to look how the rock guard looks like. I'm happy with the looks. Now only have to wait untill I can find the right materials to buy and install these piece of hard heads.
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250531_155211
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250531_153832
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) 20250531_155234
A.alansari
Qatar
Mustang GT 2024 PP
Today I did some Forscan research and did some changes:
Frost tell tale
IPC 720-01-02 xxxx x*--
Factory setting: CE17 808F
0 =disabled
8 = enabled
Autolock when driving
APIM
7D0-09-01: "xx9x" "xxxx" "xx--"
Factory settings: 6B17 492C AF87
1 = disabled
9 = enabled
IPC
720-01-01: "xxx9" "xxxx" "xx--"
Factory settings: 8F48 2C64 D262
8 = disabled
9 = enabled
BCM
726-19-02: "x1x1" "x1x1" "x1--"
BCM
726-27-01: "xxxx" "xxx1" "xx--"
Remote close Window
APIM
7D0-09-01 xxxx xDxx xx--
I Disclaimer:
1. The remote closing of the window didn't work. Even when putting the right adress in APIM.
I guess this feature is not for the Mustang, unless somebody can confirm that he/she can close the window with the remote. This is only about closing the window. Opening the window works and came as a factory setting.
2. I thought I had the Auto Lock feature from the factory, but it seemsthat Canadian Mustangs are treated just like the overseas Mustangs and is disabled from the factory and needs to be enabled with Forscan. Unless it's disabled for everybody. Can someone with a USA Mustang confirm that he has the Auto Lock feature enabled from the factory?
Tomorrow I'm going to change the TSR (Traffic Sign Recognition).
I have the North America TSR and it doesn't work with the European traffic signs.
I will share the Forscan lines when everything is working.
Also I was searching for a way to find out all the country codes, for people who want to change their vehicle to their own country. This can be handy if your language is not available in the language settings. It was a pain in the ass to find what my county code is (The Netherlands) since I have a Canadian Mustang. The only thing I knew was that the country code of:
Canada is 4341
United States 5553
Then I found a very handy tool for people who want to find out what your country code is.
See the picture below to find out what your country code is.
I haven't verified this table, but:
Canada is CA, so the letter C and A makes 4341
United States is US, so the letter U and S makes 5553
This means my country code, The Netherlands is 4E4C
The only strange thing is that there is a forum member @GK292 from Austria (AT), and he said his country code is 4155. But if I use Austria following the table, it should be AT = 4154
The country that has 4155 as a country code is Australia since Australia is AU.
So is this table not correct or did he confuses Austria with Australia?
I hope you can clarify this mystery GK292.
If it was a mistake, then this table is correct and this is how you guys can find out what your country code is. I will test this out in a couple of days after I did all my other Forescan changes with no issues.
Update:
It seems that the country codes are correct, but Ford does not have all the countries working.
For example, people from Australia can't use AU as a country code and they have to use AS (American Samoa), to have theirs working. So yes, the country codes seems to be correct, but if Ford didn't program your country code, it will not work and you have to find another country that fit's your language.
If you want to change the language to your own country you need to change it in all 4 modules:
APIM:
7D0-03-01 **** xxxx xx--
IPC:
720-04-02 **** xx--
TCU:
754-10-01 **** --
GWM:
716-08-01 **** --
I know this is old but my car has auto lock from factory gcc car in case you still need it
I meant to quote number 2 from disclaimer from the phone it copied everything 😅
Yes, that is my own message that I wrote. I shared what I changed on my car.
A.alansari
Qatar
Mustang GT 2024 PP
I only get speed signs and never seen this gray signs looks better than the red and white
No, no, my mistake not explaining the colors.
They are red and white but they turn grey after the car doesn't see other signs for a certain amount of time.
I'm talking about the information that is written on the sign itself.
What traffic signs does your Mustang read?
Only speed signs or also other signs like
- "end of speed limit"
- "no passing zone"
- "passing zone"
Etc.
A.alansari
Qatar
Mustang GT 2024 PP
My car only reads speed signs nothing else and never turns grey if there is no speed signs in street it will give me the correct speed i think it is pulling it from maps or something
Mine doesn't pull from maps because there are no map speed signs on this island.
I need to check later when I'm back in Europe how my car reacts there. But for now, I'm very happy with the fact it reads different signs.
S650 Mustang Chefchaouen GT Project (10R80, 401A, PP, AE, NPP, MR, Recaro) IMG-20250601-WA0004
Here it is red with the no overtaking sign.
A.alansari
Qatar
Mustang GT 2024 PP
Can you share the forscan addresses you have for fsr i want to compare them with mine
I'll search for them in an hour or so.
When there are no signs, what do you see on yours?
