Car Soap Shootout with DFB
DFB5.0
Australia
Mustang GT Fastback
The Concept -
During the 25 years I've been cleaning cars, I've tried more soaps than I should probably admit to. Over that time, I've found a number of soaps that have surprised and delighted. Naturally, I've also discovering plenty of duds along the way. In no way am I suggesting that this exercise is something you should follow, by and large they all do the same thing, albeit in different ways. However, with so many soaps on the market to choose from, it can be hard to know where to start, what is actually good and what is merely a shelf filler.
This thread documents every single soap I have used so far.
Soap 101 -
In detailing, soap is used for a couple of key reasons -
-To assist in the removal of dirt and contamination
-To provide lubrication during the removal of said dirt and contamination.
Those contaminants can range from the usual dirt and road grime, but also include bug, tar and iron deposits. Some will also target mineral deposits that can and will cause water spots, some help revive an aged ceramic coating, others will aid in the removal of an older LSP.
The pH value of a soap is also an important factor to consider as it ultimately determines the sort of cleaning you want to achieve. For regular washing, you want a pH neutral (7.5) or pH balanced (7.0 - 8.5) soap to help preserve your LSP and prevent premature weathering of plastics and rubber. To deal with excessive dirt, grime, bugs, oily substances and to strip waxes and sealants, a high alkaline soap will be the best choice. These alkaline soaps also help revive older ceramic coatings. For mineral deposits, an acid leaning pH is what you need.
Soap is administered via a foam gun (garden hose fed), foam cannon (pressure washer fed) and/or via a bucket and wash media (mitt, pad or sponge).
The Review -
Each product here gets a brief outline of its intentions, followed by usage notes and then a scoring system that covers the core criteria that I'm looking for in a soap. For me, I want a soap that has a pH value to suit my intentions, produces medium to thick foam, provides high lubrication, smells nice and cleans well. Probably in that order, depending on the application.
The first 3 soaps are what I consider the top 3 maintenance soaps on the market. These are the products that I use and recommend the most. The difference between the three is minor, choosing any of these will be a winner.
Carpro Reset – In my opinion, the best maintenance soap on the market. Exceptional foaming, exceptional slickness, exceptional scent and pH neutral. Reset is expensive, but this is a classic case of you get what you pay for. I keep trying different soaps, but nothing really seems to be able to match Reset as a total package.
Lubrication – 10/10
Cleaning Ability 10/10
Scent – Hard to describe, it’s simply brilliant!
PH Level – 7.5
Consistency - Thin
Overall Rating – 10/10
S650 Mustang Car Soap Shootout with DFB IMG-4551
S650 Mustang Car Soap Shootout with DFB jul211-
Koch Chemie GSF – My current number two, GSF is a pH neutral soap making it ideal for maintenance washing, offering supreme lubricity and brilliant foam quality. It’s the scent that really seals the deal, one of THE BEST smelling products in the detailing world. Again, an expensive soap, but the user experience is bloody brilliant.
Lubrication – 10/10
Scent – Cherry
PH Level – 7.5
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB img-1907-jpg
S650 Mustang Car Soap Shootout with DFB IMG-4546
NV Snow – Number three on my list, this was the first soap I bought from a specialist supplier, a massive step up from what I had been using up to that point. Snow ticks every box, slickness, cleaning ability, foam quality, easy rinsing and pleasant scent. This soap is a runnier liquid, making it easy to measure and pour.
Lubrication – 10/10
Scent – “Pleasant”
PH Level – 7.2 (Note – I have seen numbers as high as 9.9)
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB IMG-1630
S650 Mustang Car Soap Shootout with DFB dsc-0301-jpg
The next three are my top 3 decontamination/strip soaps. Use these for occasional deep cleaning or in preparation for a new wax/sealant. Unlike the maintenance soaps, these are in no particular order.
Carpro Lift – This is a high pH soap designed for decontamination. Brilliant foam quality and strong cleaning power. It does lack some of Reset’s slickness and trades a sweet scent for a stronger “chemical” smell. Use this only occasionally to deep clean a ceramic coating, when preparing for a paint correction or when prior to applying a new wax/sealant.
Lubrication – 8/10
Scent – Unscented
PH Level – 12+
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB IMG-4554
S650 Mustang Car Soap Shootout with DFB img-2116-jpg
Carpro Descale – This soap swings the other way compared to Lift, being an acidic product for decontamination washes. The acidic nature can help remove hard water spots. Descale is another product that can be used to revive an older ceramic coating. Again, a product for occasional use, I like to use this as a strip wash. Cherry scented and offering similar lubricity to Lift.
Lubrication – 8/10
Scent – Cherry
PH Level – Not Specified, my testing showed about 3.7
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB IMG-4487
S650 Mustang Car Soap Shootout with DFB img-2029-
Obsessed Garage Decontamination Soap – This is an interesting soap that will soon be freely available in Australia. It’s a higher pH alkaline soap that offers higher lubricity than the other two, offers brilliant foaming and strong cleaning ability. It has a solvent base for that added ability.
Lubrication – 10/10
Scent – Mild Citrus
PH Level – 10.0
Consistency - Medium
Overall Rating – 9/10
S650 Mustang Car Soap Shootout with DFB IMG-4253
S650 Mustang Car Soap Shootout with DFB img-4055-
The following products trace a line to the point where I have arrived at my top 6 soaps. Some are good, but not great products. Some are absolute dogs. This has been a near 25 year journey, the thrill of the chase being the motivation to keep looking, keep trying.
These are a few from my earlier days detailing -
Meguiar’s Gold Class – Available everywhere, this is a decent soap that foams up well and provides plenty of suds. This soap will leave a gloss enhancer behind, best avoided on ceramic coated cars. Being so thick and gloopy, Gold Class is harder to measure out than more runny soaps.
Lubrication – 7/10
Cleaning Ability 7/10
Scent – Musky
PH Level – 7.5
Consistency - Thick
Overall Rating – 6/10
Meguiar’s NXT – Again, available everywhere with great suds. With “synthetic lubricating oils”, NXT will also leave something behind. It can also soften hard water, meaning its safer to use in the sun. This is also a thicker soap, making it harder to measure.
Lubrication – 7/10
Scent – Fruity
PH Level – 7.5
Consistency - Thick
Meguiar’s Ultimate Wash & Wax – Another thick, gloopy soap from Meguiar’s that will also leave behind a small amount of protection. I stopped using this due to poor cleaning ability and the fact it was leaving behind a residue on glass.
Lubrication – 7/10
Cleaning Ability 5/10
Scent – Bubble gum
PH Level – 7.5
Consistency - Thick
Overall Rating – 4/10
Autoglym Bodywork Shampoo Conditioner – The single worst soap I have ever used, and one of the worst detailing products I have had the displeasure of spending money on. No suds, no lubrication, no cleaning ability. This stuff is utter garbage, run don’t walk from this pathetic product.
Lubrication – 2/10
Cleaning Ability 1/10
Scent – Can’t remember LOL
PH Level – 7.5
Consistency - Thin
Overall Rating – 1/10
Bowden’s Snow Job – I started using this when foam cannons really took off. Initially, I liked how well it foamed. As time went on, I realized this soap lacks meaningful cleaning ability. It’s thicker consistency also made it harder to pour into the foam cannon. There are far better soaps than this, if you don’t want to purchase from a specialist supplier, then look towards Gold Class or Bathe instead.
Lubrication – 6/10
PH Level – 7.5
Consistency - Thick
Overall Rating – 2/10
From this point on, I’m commenting from more resent experience.
NV Snow Plus – This soap is a higher pH / alkaline soap designed for more cleaning ability. It lacks the pleasant scent of regular snow and is a clear liquid rather than colored blue. You would use this soap on dirtier vehicles or when doing a decontamination/strip wash, Snow Plus having the ability to remove or seriously degrade a wax/sealant. A brilliant choice and a staple of my cabinet for a number of years now.
Lubrication – 8/10
Cleaning Ability 9/10
Scent – Un-scented
PH Level – 8.1 (Note – I have seen numbers as high as 12.1)
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB IMG-4563
S650 Mustang Car Soap Shootout with DFB apr246-
Adam’s Car Shampoo – This is a pH neutral soap offering superb foaming ability, decent slickness and a pleasing blueberry scent. This is also a good option for washing in full sun. It’s only drawback is a too thick consistency that makes pouring more difficult. It also a touch expensive for what it is. A decent soap, just not great.
Lubrication – 8/10
Scent – Blueberry
PH Level – 7.5
Consistency - Thick
Overall Rating – 7/10
S650 Mustang Car Soap Shootout with DFB IMG-6474
S650 Mustang Car Soap Shootout with DFB nov32-
Adam’s Mega Foam – This is like Adam’s Car Shampoo, just on steroids. It foams better while maintaining a neutral pH, it also remedies the too thick consistency by being thinner and easier to measure out. Nice fruity scent as well. The only drawback is the price, being just too expensive for what it is. I actually like this product, I would certainly order it again………when on sale.
Lubrication – 8/10
Scent – “Fruity”
PH Level – 7.5
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB IMG-5890
S650 Mustang Car Soap Shootout with DFB IMG-4680
Gyeon Bathe – Gyeon offer a number of soaps, I think this is the one to go for. This is a maintenance soap that offers a runny consistency for easy pouring, a lovely scent and stunning foam quality.
This is one of those products that seemingly nails it across the board, it foams brilliantly, ultra thick with a high cling rate, it's very slick and smells nice. But for some reason, I just don't love Bathe enough to keep it in stock.
Lubrication – 9/10
Cleaning Ability 8/10
Scent – “Pleasant”
PH Level – 6.0
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB IMG-1099
S650 Mustang Car Soap Shootout with DFB IMG-1110
Koch Chemie AS – From what I can gather, Auto Soap was most likely a car-wash gantry-applied soap which KCx put into a retail-level bottle. I promises safe but effective cleaning at a lower price than GSF.
This is an odd product that I don’t really see the point in. It doesn’t foam, it’s lemon scent is weak, and it isn’t all that good at cleaning despite a higher pH of 9.0. While it’s considerably cheaper than GSF, that is not enough incentive to give this a try. Avoid.
Lubrication – 5/10
Scent – Lemon
PH Level – 9.0
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB IMG-2200
S650 Mustang Car Soap Shootout with DFB img-1670-jpg
Optimum Car Wash Shampoo – A pH neutral soap that can be diluted up to 250:1 that's safe and effective for use on waxes, sealants and coatings.
If you like a thinner foam consistency, this is a great option. Medium thickness in terms of pouring consistency, it has a pleasant scent and offers decent cleaning ability. It's also free rinsing, meaning it doesn't reactivate during the final rinse. Another very good soap.
Lubrication – 8/10
Scent – Blueberry
PH Level – 7.5
Overall Rating – 8/10
S650 Mustang Car Soap Shootout with DFB IMG-4584
S650 Mustang Car Soap Shootout with DFB img_4588-jpg
P&S Pearl – The key attraction to this soap is the low price. P&S make some lofty claims of it high foaming ability, suggesting it has "unsurpassed foam coverage" Pearl is pH neutral and contains no gloss enhancers or wax.
I'm not going to beat around the bush here, I don’t like this soap. The high foaming claims are bogus, I just couldn’t get the thick foam quality they claim, and the type I normally prefer. The lemon scent is faint, the cleaning ability average and it’s low price is offset by needing to use more than other soaps per application. I have seen some suggestion that Pearl foams better when mixed with de-ionised water, but that is unrealistic for most. Cheap, but not cheerful.
Lubrication – 7/10
Scent –Lemon
PH Level – 7.5
Consistency - Thin
S650 Mustang Car Soap Shootout with DFB img_0698-
S650 Mustang Car Soap Shootout with DFB IMG-0712
Stjarnagloss Sno – This is one of a couple soaps offered by this brand. Sno was designed as a pre-wash snow foam, as such it's not aimed at bucket/contact washing. For me, that is a deal breaker.
While Sno smells divine and foams like a champion, producing ultra thick foam, that's where the compliments end. As a bucket soap, it lacks lubrication and feels quite odd under a wash mitt. It also stained my foam cannon pickup tube blue. As a pre-wash soap, it does sweet f-all in breaking down contaminants in a touch-free manner. Not a soap I will be re-ordering.
Lubrication – 3/10
Scent – Coconut
PH Level – 7.5
Consistency - Thin
Overall Rating – 5/10
S650 Mustang Car Soap Shootout with DFB img_4797-jpg
S650 Mustang Car Soap Shootout with DFB IMG-6797
Adam’s Ultra Foam – Like the two other Adam’s soaps I have used, this a pH neutral maintenance product. I like how these soaps foam and then rinse away nice and clean, Ultra Foam is no different. The wild berry fragrance is fun too. All three of these Adam’s soaps are really good options.
Lubrication – 7/10
Scent –Berries
PH Level – 7.5
Consistency - Thick
S650 Mustang Car Soap Shootout with DFB IMG-6025
S650 Mustang Car Soap Shootout with DFB img-6032-
Gtechniq G-Wash – Like Gyeon and Carpro, Gtechniq make a number soaps, G-Wash being their pH neutral maintenance soap. In no way is this a bad soap, it’s just not a great soap. The foaming is ok, the lubrication is ok, the cleaning is ok. The scent is not unlike GSF, however is just doesn’t reach the heights of what it should for a quality brand like Gtechniq.
Lubrication – 5/10
Scent – Cherry
PH Level – 7.5
Consistency – Thin-medium
S650 Mustang Car Soap Shootout with DFB IMG-9568
S650 Mustang Car Soap Shootout with DFB img-5555-jpg
Shine Supply Shift – I bought this soap as an afterthought and ended up being pleasantly surprised. I shouldn’t like this soap, it has slightly thicker consistency and a thinner foam quality than I like. But………I really enjoy using this product. The foam, despite being thinner, clings to the paint for a long working time and the coconut lime scent is delightful. It’s wont clean as well as Reset or NV Snow, nor is it as slick as GSF, but as a workhorse soap, it’s a pleasure to use. I like it so much I have gone and bought a gallon of the stuff.
Lubrication – 8/10
Scent – Coconut-Lime
PH Level – 7.5
Consistency – Slightly thick
Overall Rating – 8.5/10
S650 Mustang Car Soap Shootout with DFB img-5630-
S650 Mustang Car Soap Shootout with DFB img-5621-jpg
Auto Finesse Lather – I’m not going to beat around the bush here, I hate this soap!
Some of this dislike will come down to my usage patterns though. During my maintenance wash process, I rinse the car, foam it down and then do the contact wash with the foam still on the paint. I have the same soap in my wash bucket too.
Auto Finesse offer two maintenance soaps, Avalanche and the pH neutral Lather. Avalanche is geared towards pre-wash foaming and Lather is designed for bucket washing. In my opinion, I see no reason for using two different soaps during a regular maintenance wash. Lather is said to be “super foamy”, which led me to giving it a try. Except, it doesn't foam, at least not in an effective manner. The consistency is super runny and unlike other soaps that offer a thinner film, Shine Supply Shift or Optimum Car Wash for example, it doesn’t cling to the paint. The Scent had a hint of citrus, the cleaning ability ok and lubrication is fair. Overall, not a soap I will be re-ordering.
Lubrication – 6/10
Scent – Tangerine / Citrus
PH Level – 7.5
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img_6596-
S650 Mustang Car Soap Shootout with DFB img_6598-
Angelwax Fast Foam – A pH neutral maintenance soap designed primarily as a pre-soak. This is another soap I took a punt on, and I’m glad I did. The foam quality is exceptional, dwell time is fantastic with Angelwax saying the longer it stays on the paint, the more it will break down contaminants. It may not be Reset or GSF slick, but it’s not far behind. The only thing I would change about this soap would be to add a scent, Fast Foam is essentially fragrance free. A brilliant soap and certainly gets a pass from me!
Lubrication – 8.5/10
Scent – None
PH Level – 7.5
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img_6610-
S650 Mustang Car Soap Shootout with DFB img_6617-jpg
Bowden’s Own Snow Job – This is an Australian brand, one that I don’t believe is available outside of Australia and New Zealand. The original formulation of Snow Job was junk! Sure, it foamed well but it offered little to no cleaning ability. The new version is said to be an all-new formulation, addressing a few key problems with the original, including cleaning ability and the consistency of the liquid.
Snow Job v2 is now much runnier, making it easier to measure out. Like the original, Snow Job foams like a champ, producing thick and clingy foam. It also cleans better than the original, although still not to the level of the leaders. I also don’t really like the scent, almost like a commercial men’s room cleaner. Overall, an improvement on the original but not a leading contender.
Lubrication – 6/10
Cleaning Ability 6/10
Scent – Said to be “refreshing”
PH Level – 7.5
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img_6677-jpg
S650 Mustang Car Soap Shootout with DFB img_6685-
Wowo’s Detailer’s Shampoo – I ordered this soap without any expectations and ended up pleasantly surprised. The big selling point of this product is the versatile formulation. Use less (1:500), and you have a gentle maintenance wash. Use more (1:100) and you have a soap which can deal with heavier soiling. It’s also a pure soap, with no gloss enhancers or added sealants.
In use, Detailer Shampoo produces thick, shaving cream type foam, allowing it to have an extended dwell period. Slickness is great, as is cleaning ability, I also found it to be very free rinsing. The scent is rather strange, but apart from that, I found this soap to be a bit of a sleeper.
Lubrication – 8/10
Scent – Violet, An acquired taste
PH Level – Variable, but 7.5 when diluted to 1:500
Consistency – Medium Runny
S650 Mustang Car Soap Shootout with DFB img-7277-jpg
S650 Mustang Car Soap Shootout with DFB img-7293-
Ethos Foam Party – A pH neutral soap that is geared towards foaming and pre-wash soaking. Ethos is supplied by B&B Blending, which is owned by Adam's. As such, I'm fairly certain Foam Party shares a formula with Adam's Mega Foam, save for the color, scent and label design. That also means shares the attributes that makes Mega Foam great.
The ultra-thick foam is up there with the best and the dwell period excellent. Foam Party also performs well as a bucket wash, offering great slickness and cleaning ability. The pineapple scent is described as a “tropical getaway”. For the bottle size, it’s a touch expensive and the yellow colouring is not unlike diluted Betadine antiseptic, not a particularly pleasant visual in my opinion. But apart from that, I really like this soap.
Lubrication – 8/10
Scent – Pineapple
PH Level – 7.5
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img-8035-
S650 Mustang Car Soap Shootout with DFB img-8037-jpg
Mirch Blue Candy - This is a pH neutral maintenance soap that is extremely well priced. A 500ml bottle is only $14.99, 1000ml $22.99 and a 5 liter jug sits at $49.99. For comparison, NV Snow is $20.95 and $32.95 for 500ml and 1000ml respectively, a 4 liter bottle sitting at $76.50. If you are pro detailer, you can even get this product in a 20 liter drum for just on $110. (Prices in AUD)
Blue Candy is at home in a bucket or foam cannon, delivering thick shaving cream foam. Slickness and cleaning ability is on par, the rinse off easy without excessive reactivation. The scent is a strong bubblegum aroma, one that I didn't really care for. Blue Candy is not a favorite, but I can see the appeal and value it provides. If you keep an eye out, those above prices are often even cheaper on sale.
Lubrication – 7/10
Scent – Sweet Bubblegum
PH Level – 7.5
Consistency – Moderately thick
S650 Mustang Car Soap Shootout with DFB img-8884-jpg
S650 Mustang Car Soap Shootout with DFB img-8881-
DIY Detail Incredible Suds - A pH "balanced" soap that can be dialed up or down depending on your cleaning needs. While it can be used in a bucket, its main claim to fame is the ultra-thick foaming ability. So thick that DIY had to put out an updated dilution ratio to dial it back some. The candy-like fragrance is enjoyable, as is the slickness and excellent cleaning ability. But what makes it a winner in my opinion is the exceptionally easy rinse off, I have never used a soap that rises so freely. I could see this aspect being very attractive to pro-detailers looking for time efficiency. But..........
The price of Incredible Suds is just too much. A 473ml bottle is $34.95, a gallon priced at a ludicrous $179.95. Those prices rule it out for pro use, in Australia at least. A real shame, because this is an excellent product. (Those are AUD prices, so this aspect is not all that relevant for US readers, so go buy some, you will love it!)
Lubrication – 8/10
Scent – Candy
PH Level – Balanced but variable
S650 Mustang Car Soap Shootout with DFB img-8137-jpg
S650 Mustang Car Soap Shootout with DFB img-8143-
Gyeon Q2M Foam - Gyeon seem to be a bit cagey with this product by not quoting a pH level. As a pre-wash soap designed to soften and lift dirt prior to the contact wash, I suspected a higher pH is what delivers that. Tested with my pH meter, that theory played out with a reading of about 12.0. As such, I would only be using this as an occasional wash on dirtier vehicles or as a restorative decon for ceramic coatings. There is a hint of a lemon fragrance, and the foam quality is extremely thick. Think of Q2M Foam as Gyeon's version of Carpro Lift.
Lubrication – 8/10
Scent – Mild Lemon
PH Level – 11.95
Consistency – Thin
S650 Mustang Car Soap Shootout with DFB img-9180-jpg
S650 Mustang Car Soap Shootout with DFB img-9219-jpg
3D Pink Car Soap - This is a soap from a brand aimed at professional users, where ultimate showmanship is not top of mind. Its pH neutral, and excellent value in gallon format. Despite the ultra-thick consistency of the concentrate, the foam quality is thin and watery. Having said that, the soap has a long dwell period and great slickness. The cherry scent is nice and rinse off is super easy.
Not a WOW soap, but a workhorse for professionals who don't need to impress the neighbors with a heavy snow job.
Lubrication – 7/10
Scent – Sweet Cherry
PH Level – 7.8
Consistency – Thin
S650 Mustang Car Soap Shootout with DFB img-9185-
S650 Mustang Car Soap Shootout with DFB img-9209-jpg
Gtechniq W4 Citrus Foam – This is a pH balanced foaming pre-wash designed as a first step in removing heavier contamination and road grime before the contact wash. Its citrus formulation provides added cleaning ability, while the balanced pH helps protect waxes and sealants. The mild citrus aroma is nice, and it foams thickly.
During the dwell period, W4 Citrus Foam breaks down and begins to run down the panel, taking dirt with it. I like to use W4 Citrus to loosen up accumulated road grime and bugs, in turn making the contact wash safer. I will note that this product is not as aggressive as something like Carpro Lift or Bilt Hamber Touchless, but sometimes that level of grunt is not needed. W4 Citrus Foam is the happy medium.
Lubrication – not rated
Cleaning Ability - 8/10
Scent – Citrus, quite muted
PH Level – 6.4 (as tested)
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img_0065-jpg
Koch Chemie GFX – Now, this is probably a pointless addition here considering it was never offered in Australia, and the fact it was a limited edition, but I have used it and so it deserves a ranking. In theory, GFX is apparently the same as the brilliant GSF, save for the cinnamon and pine Christmas themed scent. However, there is a pH difference between the two, with GSF rated at 7.5 and GFX sitting at 8.0. I have since found out that the difference in pH was to allow the scent to hold true.
In any case, GFX performs the same as the regular version, delivers top tier lubrication and foaming ability. And yes, the scent is delightful and one that lingers long after the buckets have been emptied. GFX is about as festive as I get these days. Considering how lovely the scent is, I can see this reappearing at some point in the future.
Lubrication – 10/10
Cleaning Ability - 7/10
Scent – Cinnamon and Pine
PH Level – 8.0
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB IMG-0157
S650 Mustang Car Soap Shootout with DFB img-0185-jpg
Bilt Hamber Touchless – I’ll be honest up front in saying this soap is not designed for me, I simply don’t need its extreme cleaning power. Uniquely, this is a sugar-based soap that contains corrosion inhibitors, and with a pH of 12.0, this is one of the most alkaline soaps you can use on your car.
Touchless was designed to do what the name suggests, removing accumulated road grime, bugs and dirt without touching the vehicle. The tricky part with this soap is what Bit Hamber like to term “panel impact ratio”, which translates to the ratio achieved once the soap hits the paint after being diluted by your foam cannon. Bilt Hamber present a rather complicated process to calculate this ratio, something that will vary depending on your foam cannon and pressure washer output. Some suppliers of Touchless provide a value to start with, but frankly, you really need to calculate this for your specific application. For me, this is needlessly complicated.
In use, it’s important to note that this is not a soap you would use for a contact wash, rather it’s a pre-wash foam to make the contact wash safer. Touchless is also a runnier foam than most, blanketing the vehicle in a thin layer of soap that breaks down contamination and allows it to be drawn from the vehicle as it drips onto the ground. After rinsing, you will be surprised at how effective this product is at removing dirt without laying a hand on the car. All I can say is, be careful with it.
Lubrication – N/A
Cleaning Ability - 15/10
Scent – Unscented, slight sugar cane type aroma
PH Level – 12.0
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img-9963-jpg
S650 Mustang Car Soap Shootout with DFB IMG-9959
Chemical Guys Honeydew Snow Foam – One of the brands best products, this is a pH neutral soap that boasts impressive foamability and suitability for use on waxes and sealants. I note that it has gloss enhancers, which could work against you on a ceramic coating.
In use, Honeydew is easy to dispense due to its runny consistency. The foaming ability is exceptional, the slickness middle of the road. The scent is pleasantly fresh, although not a standout like GSF or Reset. The soap also rinses freely. I used this soap on vehicles with Gyeon Pure EVO ceramic coating and didn’t seem to have compatibility issues from the glossing agents.
This is a very competent soap. However, in Australia Honeydew is priced against some heavy hitting soaps, making it a hard sell for me. The overall score reflects this.
Lubrication – 7/10
Cleaning Ability – 7/10
Scent – Subdued honeydew aroma
PH Level – 7.5 (claimed)
Consistency – Runny
Overall Rating – 5/10 (At US prices, I would put this at 7/10).
S650 Mustang Car Soap Shootout with DFB img-1429-
Meguiar's Hyper Wash D110 – A highly concentrated soap with a 400:1 dilution ratio that is aimed at professional or bulk usage. In the US market, Hyper Wash is exceptionally affordable, priced below something like Adam's Car Shampoo or Mega Foam. In Australia, the $95 RRP puts it above the excellent 4-litre NV Snow or 3.8-litre Optimum Car Wash.
According to the SDS, Meguiar's doesn't provide a number in their marketing information, pH value of Hyper Dressing is about 9.0 to 9.8. In in theory, this delivers increased cleaning ability and improved wash efficiency. The formula is biodegradable and can be used in a professional metering system.
Meguiar's claim of "rich, stable foam" certainly rings true, Hyper Wash blanketing the car with shaving cream thick foam. The scent is pleasant but somewhat muted, so it won't "out scent" a soap from the likes of KCx, Carpro or Gyeon. While not class leading, slickness is agreeable and cleaning ability impressive. The thicker consistency of the concentrate does require more diligence when mixing up foam cannon and bucket solutions. Due to that thickness, this is a soap I would highly suggest fitting a dispensing spout/tap, especially if you have a narrow foam cannon opening.
Overall, an impressive workhorse soap that I have enjoyed using far more than I expected. If you are looking for something different as bulk soap, Hyper Wash is an attractive proposition. Just wait until its on sale though.
Lubrication – 9/10
Scent – Mild, Pleasant.
PH Level – 9.0 to 9.8 (Note – I recorded 7.89)
Consistency - Thick
Foam Quality - Thick
S650 Mustang Car Soap Shootout with DFB img-1495-jpg
S650 Mustang Car Soap Shootout with DFB img-0027-jpg
P&S Frostbite - Debuting earlier this year, this is an alkaline leaning soap aimed at ceramic coating maintenance or when additional cleaning power is required. Frostbite was primarily designed as a foaming pre-wash, the ultra-thick foam clings to the vehicle to soak, break down and encapsulate contamination.
In use, Frostbite immediately impresses with thick shaving cream foam, in fact this is the first P&S soap that actually foams properly. I have used this soap as a pre-wash and as a contact wash, its abilities on both counts average at best. Diluted, foamed and allowed to dwell as recommended, I found most of the road grime still on the paint. Frostbite is nowhere near as effective as Bilt Hamber Touch-less in this regard. As a contact wash, it's not the most lubricious either. The scent is quite unique, a "Eucalyptus-mint" aroma. Measured pH sits at around 10.77.
Overall, not a standout product in my opinion.
Lubrication – 5/10
PH Level – 10.77 (measured)
Consistency - Thin
Foam Quality - Ultra Thick
S650 Mustang Car Soap Shootout with DFB img-0409-jpg
S650 Mustang Car Soap Shootout with DFB img_0132-jpg
Coming Next - Wash & Wax Series
MCS
SW Ontario
'24 DH Premium
S650 Mustang Car Soap Shootout with DFB 1726661979259-ek
@DFB5.0 it's too early for that much thinking. It's not even 0820 Eastern!!!
I've been using RESET since my S550 and find it was super super easy to use. It didn't foam up a lot when doing just a two bucket + wash mit however now that I have a pressure washer on the way yeah, I'll be following the guidance in our discussions and making that shaving cream foam!
I'm actually trying to put together a SOAP DETAIL KIT list.
I've been thinking.....
- CarPro RESET (as my regular weekly wash)
- CarPro LIFT (after a long road trip)
- CarPro RELOAD (used after the CLEANING methods above - once every 2-3 months)
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
@DFB5.0
Reset and Lift would be a great combo.
I like Reload, but don't rule out Armour Detail Supply Amplify (more of a competitor to Carpro EliXir and can be used more often) or Armour Detail Supply Ceramic Spray Sealant (Reload competitor), both are easier to use than EliXir and Reload.
AMPLIFY - Detail Spray – Armour Detail Supply
Ceramic Spray Sealant – Armour Detail Supply
S650 Mustang Car Soap Shootout with DFB IMG-0977
S650 Mustang Car Soap Shootout with DFB IMG-1157
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
WASH AND WAX SERIES
I’ve never really been a fan of these soap. In my earlier years, a product like this would have been quite useful in topping up my Mothers California Gold Carnauba Wax I was using at the time. But, in recent times, more durable forms of protection have, in theory, made wash-n-wax soaps redundant. This is especially important on ceramic coatings due to the potential to cause streaking or smeary results. I‘ve also found the use of a spray sealant as drying aid has eliminated the need for adding protection via the wash soap.
But, as coatings have become the norm, the manufacturers have updated the concept of a wash-n-wax by swapping the wax for Si02 ceramic chemistry. However, the concept remains the same, the soap being a convenient way of maintaining your LSP.
So, how do these soaps stack up against regular wash soaps? Are they worth the bother these days? Can they transform unprotected paint? Let’s find out………………………………
P&S Radiance Wash & Wax – This is NOT a modern product and has actually been discontinued. I was actually sent a bottle of this in error instead of the newer Inspiration Radiance. I subsequently threw it into the back of the cabinet and forgot about it. In the end, I grabbed it and took it to work to clean the company delivery vans with. I was pleasantly surprised……………………..
The moment you open the bottle, you can tell this is an old-school car wash soap, the dated fragrance is straight out of the 90’s. I used this soap on completely bare, unprotected paint and came away impressed. Firstly, it cleaned quite well, felt nicely slick. The finished result actually added some decent water sheeting to the paint and glass, not to mention a boost in gloss and slickness. Overall, I enjoyed using this soap. But it also left me with a theory…………………..
As mentioned, Radiance Wash & Wax was recently replaced by Inspiration Radiance Coating Maintenance Wash. In theory, the new product was reformulated for modern paint coatings in mind. But…………………..having used both, well they feel, smell and work exactly the same. So, did they just change the name and put it into a new bottle. Or have they in fact reformulated it. In any case, both are nice to use, both increasing gloss and slickness, they both require generous dose rates.
Lubrication – 9/10
Cleaning Ability – 8/10
Scent – 1/10
PH Level – 7.5
Consistency – Medium thickness
S650 Mustang Car Soap Shootout with DFB img-1275-jpg
P&S Inspiration Radiance – this is an update to the older P&S formula, the original being a wash-n-wax type of soap. Because waxes and conditioning agents don’t always play well with ceramic coatings, P&S reformulated Radiance with Si02, in the process making it suitable for vehicles with an existing ceramic coating. That doesn’t mean that it must be used on ceramic coatings though, its use will add some short-term protection and gloss enhancement to any LSP.
I’ll be honest in saying that I have never been a fan of this style of soap, but Radiance was a pleasant surprise. Foaming wise, this is a very running product, so don’t expect shaving cream foam. The scent is also very dated in having an old-school car wash aroma. And the lubrication is only fair. But once the car has been rinsed and dried, the boost in gloss and slickness is very hard to ignore. So while some of the below scores are middle of the road, the final score reflects what it does to the visual and tactile qualities it brings to the table.
Lubrication – 6/10
Scent – Berry, quite muted
PH Level – 7.0 (as tested)
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img-1348-
S650 Mustang Car Soap Shootout with DFB img-1354-
Carpro Hydr02 Lite – Carpro were one of the pioneers of spray and rinse type sealants with their Hydr02 line. In addition to Hydr02 (concentrate) and Hydr02 Lite (RTU), Carpro also created Hydr02 Foam. As the name suggests, this takes the water delivered Si02 sealant and pairs it with a pH neutral soap. In addition the “significant UV protection”, Carpro say Hydr02 Foam is resistant to acids, alkaline chemicals and solvents. They also suggest it produces “amazing rich foam”. Um………………..
Like Reset, Hydr02 Foam is a clear, runny liquid that makes it easy to pour. Unlike Reset and despite the name and claims, Hydr02 Foam DOES NOT foam. It’s seems to be even worse than the others, the below shot was taken seconds after application, the foam generated is super thin and simply does not cling to the surface of the vehicle. In its defense, Hydr02 Foam(ish) is said to last up to 3-months and seemed to provide the most obvious before and after by improving gloss, slickness and hydrophobics after use.
Overall, I just couldn't get past the lack of foam on the surfaces I was cleaning. I think I will reserve this soap for neglected customer cars as a final step instead of maintenance washing my own coated vehicles. As a Carpro fanboy, this is the worst Carpro product I have used.
Lubrication – 6/10
Cleaning Ability – 6/10
Scent – Not scented, smells the same as other Hydr02 variants
Consistency – Runny
Overall Rating – 3/10
S650 Mustang Car Soap Shootout with DFB img-0714-jpg
S650 Mustang Car Soap Shootout with DFB img-0717-jpg
3D Si02 Ceramic Wash – Recently released, the soap joins a wider range of Si02 slanted products from 3D. Apparently this is a “game-changing ceramic car wash soap” with an “advanced Ph-neutral formula” that will offer deep cleaning ability. Naturally, there are claims of increased gloss and slickness, an “unmatched glow and superior protection”.
The foam is of the runny kind, much like Nano-Magic or Inspiration Radiance and considerably better than the disappointing Carpro Hydr02 Foam. However, it doesn't quite transform the paint like Hydr02 Foam does, at least how I used it without contact on this occasion. I also didn't care for the dated fragrance, so overall not a winner for me.
Lubrication – Not Assessed
Cleaning Ability – Not Assessed
Scent – Like laundry detergent, very dated
PH Level – pH neutral (claimed)
S650 Mustang Car Soap Shootout with DFB img-0848e-jpg
Shine Supply Shine Soap – said to clean and enhance any wax, sealant or ceramic coating, Shine Soap is pH balanced and apparently won’t alter the protection already on the vehicle. Strangely, the product description suggests this is a “low-cleansing soap”, in theory not diminishing waxes and sealants. As such, you would probably need to team this soap with a pre-wash soap if added cleaning power is needed. Shine Soap is said to be a polymer-based product, but I don’t see any mention of their being Si02 within the formula. Able to be used in a bucket or foam cannon, just don’t expect shaving cream foam.
The first thing to note with this soap is the near-identical scent used in Inspiration Radiance. That’s to say a very subtle but dated aroma. Secondly, it does not foam, rather it produces soap water from a foam cannon. That aspect is par for coarse with this segment, so I guess its no better or worse. Slickness I found ho-hum, almost sticky under the wash media. The lack of foam does mean it’s extremely free rinsing. Gloss and slickness afterwards middle of the road, Inspiration Radiance easily eclipses it in that regard.
I also found Shine Soap altered the characteristics of the underlying protection more than the others in this comparison, as in smaller beads and reduced hydrophobics. That may or may not bother you.
Lubrication – 5/10
Cleaning Ability – 5/10
Scent – 1/10
PH Level – Listed as “balanced”, so expect 7.0 to 8.0
Consistency – Runny
S650 Mustang Car Soap Shootout with DFB img-1327-jpg
S650 Mustang Car Soap Shootout with DFB img-1329-
Ethos Ceramic Shampoo – While specifically designed to work with ceramic coatings, this soap will also play with waxes and sealants. With Si02 in the formula, Ceramic Shampoo will enhance and prolong the underlying ceramic coating, while also providing sufficient cleaning ability and foam. Unlike other products here, Ethos Ceramic Shampoo has a less obvious look and feel after use, Ethos suggesting the “hydrophobic effects increase with every wash, water beading effect does not appear instantaneously upon first use.” To me, this means it contains less Si02, so don’t expect this to transform bare paint.
Of the soaps tested, this is the one I liked the most, and by a clear margin too. The fact it actually foams is a big part of that! The pleasant “cucumber-melon" scent of Ceramic Shampoo is quite subdued compared to other Ethos products. Slickness was decent too. Probably the only one of these I would buy again.
Lubrication – 8/10
Scent – 8/10
S650 Mustang Car Soap Shootout with DFB img-0696-jpg
S650 Mustang Car Soap Shootout with DFB img-0699-jpg
Koch Chemie Nano Magic – Described as a high-gloss soap with long-term sealing properties, it won’t strip previously applied waxes and sealants. Don’t go into this product expecting GSF levels of foam quality, but it does blanket the vehicle in a thin layer of soap that holds on quite nicely. Using the wash mitt and then rinsing activates that Si02 element.
In use, the soap is decently slick, but again, not to GSF levels. The scent is that very distinctive and pleasant KCx aroma. Interestingly, the pH level is acidic leaning. Nano Magic is best used as a light maintenance rather than a heavy-duty cleaning soap, just don't expect it to transform flat, un-protected paint. I've also found it to induce sheeting rather than ultra strong beading like Hydr02 Foam does.
Lubrication – 8/10
PH Level – 5.5
Consistency – Thin
S650 Mustang Car Soap Shootout with DFB img-9222-jpg
S650 Mustang Car Soap Shootout with DFB img-9229-jpg
Conclusions -
I've come to the realization that these soaps are not for me. While they certainly add some protection and slickness to the equation, they lack the foaming ability that I prefer and have a strange feeling underneath the wash media.
Of the soaps used for this comparison, the clear winner for me was Ethos Ceramic Shampoo, primarily because it foamed properly and felt the nicest to work with. Carpro Hydr02 Foam seemed to have the most protection potency, but was a letdown in every other way. Inspiration Radiance produced the most visible gloss and slickness improvement. Of the products that produced watery foam, Nano Magic seemed to have the most holding power.
While I can see these soaps have a purpose, they are targeted at a very specific user who just wants some beading and gloss without having to apply a ceramic coating, wax or sealant. For me, what they bring to the table does not out way their lack of foaming ability, lower cleaning potential, so-so slickness or weird scents.
Next, "dawn-ing" it up..........................
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
Why Dawn is NOT a good idea!
Using dishwashing detergent to "strip" or remove wax has been a pet hate of mine for a long time. Those that do use it, usually do so along the lines of "I don't need to buy some fancy soap to strip wax when I can just use some cheap dish washing detergent".
This video explains why using dish wash as a stripping agent is flawed -
(From 6.25min)
So, instead of removing the wax, the detergent is actually coating it with something else, disguising the wax or sealant still remaining underneath.
This becomes an issue if you intend to apply a fresh coat of wax directly after the wash, as it will prevent the product from bonding properly with the paint. If you go on to polish the paint before reapplication, that detergent residue has the ability to impede the effectiveness of the polish compound and pad.
On the flipside, if you use a clay bar after the wash, that may remove some of the residue, likewise an IPA wipe down prior to polishing/waxing will knock some of the residue back too.
But the whole use of dish washing liquid really is counter intuitive. The whole point of the exercise is to strip or remove paint contamination and waxes. Except, you end up doing the complete opposite as dish wash by nature is designed to leave something behind. So, you end up wasting your time.
Effective Strip Washing -
Most detailing brands offer specific products for this role. Typically, these are high pH alkaline soaps, although some are on the acidic side like Carpro Descale. The concept is the same though, using a higher or lower pH increases the cleaning ability, cutting through old waxes and sealants in the process. The acidic ones can also help remove or diminish the minerals that cause water spots.
Alkaline Soaps -
In addition to the below soaps, you can add All-Purpose-Cleaner concentrate to your normal car wash soap. While this is a workable solution, you won't get a consistent result, you may end up having it too strong or too weak. In other words, save the hassle and just buy the right tool for the job.
Armour Detail Supply Decon Shampoo
Bilt Hamber Auto Foam
Carpro Lift
Gyeon Q2M Foam
Griots Foaming Surface Prep
Koch Chemie Super Foam
Labocosmetica PRIMUS 2.0
NV Snow+
Obsessed Garage Decon Soap
P&S Frostbite
S650 Mustang Car Soap Shootout with DFB IMG-2120
Acidic Soaps -
These soaps are primarily targeted towards the removal of mineral deposits, but they will also strip waxes and sealants, or put a dent in an aged ceramic coating. Acid leaning soaps can also revive a "clogged" ceramic coating and restore its hydrophobic properties.
Adam's Strip Wash
Carpro Descale
Koch Chemie Reactivation Shampoo
Labocosmetica PURIFICA
S650 Mustang Car Soap Shootout with DFB img-2332-jpg
Next, some recent recruits.
radar
Melbourne AUSTRALIA
2017 GT Convertible 5 Litre V8
Well done DFB.
I like how you prefaced it with your “Current Top 3”
Please keep doing that.
Thanks to you my pair are washed with Reset and NV Snow.
Garage queens, so pretty much all I need.
I’m running a durability comparison on Beadmaker v Boost V2 - unbeknown to a friend on bonnet of his car.
I look forward to your Drying Aid and Protection article.
I think I read you now feel there is Armour product from Autobuff in Ringwood that - outshines - Beadmaker and Boost V2.
Thx again and appreciate the effort you put in
Another EPIC review! 👍
Considering giving Car Pro Reset a try; based on your review. The advert for it on Auto Geeks site recommends 1 oz/5 gals. Do you use more or less than that? TY!
PS: Shop around! $15.99/500ml on Auto Geeks vs $29.99/500ml on one Amazon advert I looked at.
MCS
SW Ontario
'24 DH Premium
You don’t foam with reset? I’m not familiar with NV Snow but have my pressure washing kit on the way so am looking at options. I’ve used reset for a couple of years and heard of foams up well
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
Reset is extremely concentrated, Carpro suggest up to a 500:1 dilution is achievable.
Pardon my conversion here, I function on milliliters and liters.
1oz = 30ml
5 gal = 19 liters
In a foam cannon, Reset will foam down to 60 - 80ml in 940 - 920ml of water, but I usually do about 100ml to 900ml of water.
In a bucket, I don't measure it, probably about the recommended 30ml. Start with that and add more if your feel the need.
WASH AND WAX SERIES
I’ve never really been a fan….
Was kinda hoping for your thoughts on ‘Mothers California Gold Carnauba Wash & Wax’
