DFB's Detailing Garage
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
Tool Cleaning Day………………………………
Surprise, surprise, I like clean tools. Considering my line of work, that isn’t always possible, so it ends up being an occasional attempt. It doesn’t help when someone returns a borrowed tool in dirty condition……………………😡
Kranzle K1152 –
This was actually on the to-do list waaaay back in September last year. Someone borrowed my beloved pressure washer without asking, then returned it covered in mud…………..and no apology. That same person also borrowed my new MS271 chainsaw, then returned it filthy and covered in sap. Anyway, the day I was going to return the pressure washer to DFB-spec, my Dad decided he would borrow it as well……………………………. I only got it back on Monday, 9-months later! My neighbour once told me that “you can lend your wife, but not your chainsaw”. Not a very PC thing to say these days, but the notion of not lending good tools I can certainly appreciate, thus I don’t recommend lending your $2000 pressure washer or near-new chainsaw.
S650 Mustang DFB's Detailing Garage IMG-5577
S650 Mustang DFB's Detailing Garage IMG-5578
S650 Mustang DFB's Detailing Garage IMG-5580
Ironically, the best way to clean a pressure washer is..............with another pressure washer. But first, the hose was dragged all the way out, then Brake Buster applied to it and the machine itself. A little light agitation with a soft brush, then everything was rinsed. Following that, some Hydr02 to assist with drying, then Shine Supply Decked Out to add some lustre to the plastics.
I feel so much better now! 😎
S650 Mustang DFB's Detailing Garage IMG-5582
S650 Mustang DFB's Detailing Garage IMG-5585
S650 Mustang DFB's Detailing Garage IMG-5591
Husqvarna 522L -
I bought this trimmer back in November 2018, and I have to say, it’s been one of the most reliable pieces of machinery I’ve ever owned. At the time, it was the first non-Stihl branded tool I had bought, so a leap of faith on my part. And it was a leap that’s paid off.
S650 Mustang DFB's Detailing Garage IMG-2181
And over the 6.5-years it’s been in service, I’ve done very little to it. Service items include 1 air filter, 1 fuel filter, and 1 spark plug. The OE-fit cutting head was replaced by a Speed feed head, which had its bump cap replaced last year. The muffler spark arrestor has been removed and inspected probably three times, but this thing burns so clean that I’ve never needed to clean it. And finally, regular greasing of the gearbox. Other than that, I’ve not had it break down or require repair.
Out of curiosity, I recently yanked the muffler off to inspect the bore and piston, both look almost new. Other than the initial fill from the dealer when I bought it, this unit has been run exclusively on Stihl HP Ultra. Just a word of warning, when shopping, there are two "HP" oils. The regular red HP is mineral based, and despite claims otherwise, I've found this stuff plugs up exhaust screens and exhaust ports in no time. The HP Ultra is fully synthetic and a murky green/brown colour.
S650 Mustang DFB's Detailing Garage IMG-5321
Being a fully synthetic 2-stroke oil, it's said to burn cleaner, which means less carbon deposits both inside and out of the engine. The lack of carbon keeps the muffler screen and exhaust port cleaner for longer, which means less maintenance and more performance. Stihl also suggests HP Ultra can clean the piston, crankcase and cylinder of engines ran on mineral based oil and fuel mixes. I have seen where it did indeed lightly remove carbon from an older engine, but it's probably better to start using it from the beginning of the engine's life. It's expensive, but that is balanced by reduced maintenance and longer machine life. There is a certain subset who don't like this oil, some even calling it muddy-water-fuel. But as far as I'm concerned, the proof is in the pudding.
I'm very much a numbers man, so this is a basic run down of what the 522L has cost me over the years, excluding fuel.
Purchase Price 2018 - $424.00 (in 2025, these retail for $679!!)
Air Filter – $19.50 (Filter and pre-filter)
Fuel Filter – $17.95 (OEM)
NGK BPMR8Y Spark Plug – $7.95
Speed Feed Head – $59.95
Head Bump Cap - $25.00
Grease - $3.00 (approx.)
TOTAL: $557.35 (AUD)
Considering the number of lawns it has been used on over the last 7 years, that total is miniscule. In addition to its reliability, I specifically love how light this machine is compared to every other straight-shaft trimmer on the market, just 4.2 kg where most start at 5.0 kg. The 522L also has an excellent anti-vibration system that cured the jitters I would get from previous trimmers. In both cases, I'd happily pay a premium for those benefits.
Anyway, I was looking at the 522 the other day and thought it was about time to remove the years' worth of grime that had accumulated.
S650 Mustang DFB's Detailing Garage IMG-5552
Another thing to admire with the 522L is how the majority of the exterior components can be removed independently. This is especially noticed on the starter, which can be removed for service via three T27's and without other pieces needing to come off the machine.
S650 Mustang DFB's Detailing Garage IMG-5558
S650 Mustang DFB's Detailing Garage IMG-5561
S650 Mustang DFB's Detailing Garage IMG-5563
S650 Mustang DFB's Detailing Garage IMG-5564
Each piece was pre-soaked with Surfex HD at 1:1, then scrubbed in the parts washer, which has Surfex mixed at 4:1. The exception being the starter, which in an attempt to avoid oversaturating the recoil parts, I used compressed air first to remove the bulk of the grime. After each piece was scrubbed, I rinsed using clean water and applied Meg's Hyper Dressing.
S650 Mustang DFB's Detailing Garage IMG-5566
From there, I used compressed air, Surfex and the pressure washer to clean the engine assembly, shaft, gearbox and debris guard. The air filer on a trimmer never really need attention due to how the engine operates above the dust zone, so I just gave them a quick blow out.
It was then time to reassemble.........................
S650 Mustang DFB's Detailing Garage IMG-5569
S650 Mustang DFB's Detailing Garage IMG-5572
S650 Mustang DFB's Detailing Garage IMG-5575
Back to spec! Here's hoping I get another 7-years out of it. :fingerscrossed:
Paul2020
Australia
2024 Mustang GT Atlas Blue
Used the Gyeon wheel cleaner this afternoon, is very good. Wheels look new..
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
The XR8 was let out of captivity on the weekend, and boy did she love the crisp winter air! In such conditions, this is a car that you need to hand on for dear life, especially when you have full traction and the torque limiting is unleased from third gear onward.
Of course, the side benefit of having the car out…………………………. I get to wash it!
The wheels were cleaned with Reset, tyres with Brake Buster. I then rinsed the whole car thoroughly before moving back into the garage for a rinse-less wash. Product of choice, Opti-Coat No Rinse. I keep forgetting how good this product is, if you like a slick feel during and after, look no further.
Optimum Opti-Coat No Rinse Wash (473ml) - Detailing Shed
Opti-Coat - No Rinse | The Rag Company
S650 Mustang DFB's Detailing Garage IMG-5633
Originally, this product was only available from Opti-Coat installers as part of an exclusive maintenance range. In addition to the lack of availability, it carries a premium price tag and only comes in 473ml / 16-oz bottles. So, its clearly not for everyone, but its pure joy to use.
As you can see, I carried the Optimum/Opti-Coat theme going. The Gloss Enhancer was lightly used as a drying aid, less is more with that product. While Opti-No-Rinse is brilliantly slick on its own, I wanted to see how the two products played together. The excellent Glass Clean and Protect finished off the exterior glass.
Optimum Instant Detailer & Gloss Enhancer Concentrate - Detailing Shed
Instant Detailer & Gloss Enhancer | The Rag Company
Optimum Opti Glass Clean & Protect - 504ml - Glass Coating - Detailing Shed
Opti-Coat - Opti-Glass Clean & Protect | The Rag Company
S650 Mustang DFB's Detailing Garage IMG-5627
S650 Mustang DFB's Detailing Garage IMG-5636
Some Clean Maker went on the wheels, the tyres got a layer of OG Tire Dressing. Back to DFB spec, the XR8 was moved back into its spot and covered up for another day.
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
I think its pretty safe to say that I’m fairly anal when it comes to detailing towels and microfiber. Be that the buying of towels, having the right towel for each task, selecting a weave type that will suit my methods, how many towels I need per car, even what colour they should be. But most importantly, how they are cleaned, dried and stored.
S650 Mustang DFB's Detailing Garage IMG-5305
A products performance and ultimately the end result will only be as good as the towel paired with said product. And that not only applies to poor quality towels, but also good quality towels improperly maintained. You can buy the most expensive premium blend Korean towels, but they will only deliver that premium feel for so long without proper care. Now, I have covered microfiber selection and care multiple times, so feel free to follow the below links.
Microfiber 101 with DFB | 2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt, Mach 1) - Mustang6G.com
Microfiber Towel Care | 2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt, Mach 1) - Mustang6G.com
S650 Mustang DFB's Detailing Garage IMG-7312
However, I’ve recently changed my process for laundering microfiber towels. For the most part, each step remains, but with one key alteration…………………….
- Place used towels in a clean bucket with sealable lid to prevent the products from drying within the fibres while I continue to work.
- Where possible, never leave used towels sitting for more than a few hours, wash them ASAP! I know the temptation is to wait until you have a full load to launder, but you significantly risk ruining your towels by doing this. The sealable bucket helps here as it prevents the products setting up in the fibres.
- Using Rag’s To Riches as the detergent, I run towels through the washing using the lowest heated setting. If they are excessively dirty, I will use an the “intensive” or extended cycle. The heated water is something I’ve been doing for a while now, which in theory helps purge grime from the towels better.
- Air dry towels indoors, then fold and store in airtight containers, inspecting each as you go for foreign material not removed from the wash (this can happen to the best of us).
For the longest time, I have air-dried towels indoors. Excessive heat can damage (read: melt) the fibres, while indoor drying helps prevent contamination from dust and debris carried by the wind.
S650 Mustang DFB's Detailing Garage k88888
However, on several occasions now, I’ve noted comments saying that running towels through the dryer will produce softer towels with less chance of linting. I’d previously dismissed the use of a dryer due to always being of the belief that heat was an enemy to microfiber. But in the last month or so, I’ve switched to using the dryer. And WOW, what a difference!!
S650 Mustang DFB's Detailing Garage IMG-5647
To clarify, you should NOT be putting microfiber towels into a dryer and running the machine on the highest setting. You WILL ruin your towels by doing that. Instead, choose the lowest heat setting and run them over a longer period. Also, clean the lint trap before starting. Regardless of material, you should be doing that every time you use a dryer anyway, but on microfiber, its especially important.
The combination of warmth and airflow helps fluff the fibres and draws any potential lint into the trap. The result is a considerably smoother, softer towel. This is especially noticeable on plusher towels such as the Eagle Edgeless, Bowden’s BGS, Gauntlet and wash media. Below are two plush 500 gsm Eagle Edgeless towels. The one of the left was air dried, the one of the right went through the dryer. If you look closely, the towel on the right is fluffier and its fibres are finely separated. The air dried towel on the left has its fibres laying flat and almost matted together. In the second photo, this explains why you can see the imprint of my hand on the machine dried towel, but less so on the air dried version.
S650 Mustang DFB's Detailing Garage IMG-5643
S650 Mustang DFB's Detailing Garage IMG-5641
So, if you feel like your towels have lost some of their softness, even with appropriate care, then I’d highly suggest trying the use of a drier. Likewise if you are having problems with linting. It might just save you having to buy new towels.
Frogdog1
Dixie
To kick things off, here is a recent detail.
Sanity detailing today, the XR8 was next in line. Tires were cleaned with Shine Supply Wise Guy, wheels and body washed with Carpro Reset. After drying, I went over the tires with Tarminator to give them a reset, then dressed with ADS Tire+.
But it's the Amplify I want to focus on. Not sure why, but I have struggled with streaking on this car for a quite a while now, especially on the hood. And that covers a wide range of products including polymer spray sealants, ceramic spray detailer/sealants, simple quick detailers, even a rinse-less wash.
In recent times, I've had nothing but good things to say about ADS Amplify, especially in relation to its ability to wipe on and flash away to a streak-free finish. Using it on the XR8 was going to be its biggest challenge though. So, you can imagine how pleased I am knowing that Amplify passed this test and delivered a streak free finish on the XR8 for first time in ages. So, I used it on the paint, glass, door jambs, engine bay, wheels and exhaust tips.
AMPLIFY - Detail Spray – Armour Detail Supply
S650 Mustang DFB's Detailing Garage {filename}
This car doesn't get driven very often, but when it does, it's always a special occasion. It also turns 10-years old in November. Of all my cars, this is the one I'm most protective of, they simply don't make them anymore and are virtually irreplaceable. I bought this car as a keepsake, it marks a moment in time when Australian's built their own cars. These high-performance Falcons were "our" Mustang, the powerful V8's and turbo-charged inline 6's were what made them a weapon.
When Ford announced the closure of their Australian factories and the retirement of the Falcon nameplate, I was gutted. Think of it this way, how would you feel if Ford decided to close Flat-Rock and discontinue the Mustang after 60 years? It would be like a punch to the gut. That's how Aussie Ford fans felt, and still do to this day. I'm lucky to have owned and driven a number of them over the years, the very first car I ever drove was a Falcon! At the moment, I have two that will never leave me, both factory ordered by me to my spec. They may be just a humble "tarted up taxi", but they represent so much more to me.
And if you wondering what these cars have to do with a Mustang, well the XR8 uses the gen-1 Coyote block and heads as the starting point, Ford then hand built them in Australia using a variety of locally sourced parts, the signature touch being a Harrop Supercharger. This was the first factory supercharged Coyote in the world! To protect the driveline, these engines only rev to 6250rpm and not the 6800 to 7500 used on Mustang Coyote's. Not that it needs those extra revs, the supercharger makes it pull from idle to rev limit.
Each engine has the initials of the tech who assembled it engraved below the supercharger snout, mine made by Mr. Stevie Voice.
Thanks for reading! :like:
The population of Austrailia is only 26 million. If you draw a half circle from Los Angeles to San Diego, that's about how many people live there. Manufacturing vehicles for a population of only 26 million (plus a few exports) isn't a profitable venture. I know that to be true as I was over a company that designed and built over the road vehicles in Australia as well as one in the states.
We decided to sell or close the Australian company as the profit was very hard to come by. We couldn't sell it for the sames reasons we had problems, so we shut down operations. So, that's what's going on in the cessation of automobile manufacturing there. Australians are very innovation and they have other good qualities but being in business always requires profit and some people believe that to be a "dirty" word. It's just a fact of being in business. FWIW.
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
The death of the Australian car manufacturing was from a 1000 cuts. But.........................
It was profitable for GM, Ford and Toyota when the Victorian and Federal Governments were dumping money into each company under the veil of "co-investment". That money got syphoned back to Detroit and Japan and the companies run at a loss on paper to avoid paying income tax. The government kept the money flowing under the idea that it kept jobs alive, but the reality is, they companies involved were sending that money out of the country. When the government money stopped, suddenly it wasn't "profitable" anymore.
So you are correct.................it's all about profit.
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
Spent some time cleaning and protecting the XR6's steering wheel today. Having not opted for leather trim, the steering wheel is the only leather inside the car. The gear selector, selector gate and handbrake boot don't count, they are vinyl.
Today, I only needed ColourLock Mild Leather Cleaner with the ColourLock brush, Strong Leather Cleaner would have been overkill.
S650 Mustang DFB's Detailing Garage IMG-5658
Once wiped dry, two layers of ColourLock Leather Protector was applied with a sponge.
S650 Mustang DFB's Detailing Garage IMG-5661
The condition of the selector gate and hand brake boot are showing age now, having developed cracks in the material. At some point, I probably should replace them but I'm apprehensive about tearing the console apart to deal with it. For now, I cleaned them with Mild Leather Cleaner, then followed with ColourLock Artificial Leather Protector.
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
This is how I detail a mower.......................
The test subject was my Victa Mustang 750iS with the battery powered push-button start. With that in mind, I removed the battery and made sure to tape up the connections before starting.
In this case, I used Shine Supply Wise Guy, but I've used P&S Brake Buster and Bilt Hamber Surfex HD in the past as well. In other words, an alkaline degreaser to target oil, dirt and grease.
S650 Mustang DFB's Detailing Garage IMG-5729
Once clean and while the mower is still wet, applied Hydr02 and rinsed immediately to distribute. Hydr02 is great for this sort of thing because it means you don't need to access every nook and cranny, the stream of water does that for you. Following that, a misting of Meguiar's Hyper Dressing to make it pop!
S650 Mustang DFB's Detailing Garage IMG-5734
A blow down with the EGO and a quick wipe, the job was done. If I wasn't filming, this process would take me less than 5 minutes.
S650 Mustang DFB's Detailing Garage IMG-5737
S650 Mustang DFB's Detailing Garage IMG-5738
Just note that I'm not doing this on a weekly basis, its an occasional thing to keep the mower looking nice. Considering the mower is now 3-years old, I think this method is working well.
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
I always forget how much extra work it is to maintain a car in winter. Wet or damp roads, and the road film and mud the comes from that, well it generally takes more time and more chemical aggression to deal with. In the Wildtrak's case, transporting a dog with wet and muddy paws every day, off roading and pulling a boat out of the river doesn't help the situation.
I actually pre-treated the wheels, tyres and wheel arches with Bilt Hamber Touch-less, followed by contact washing with P&S Brake Buster and Undressed. For the paint, I tried P&S Frostbite, which apart from the unique Eucalyptus-Green Tea scent, it's thoroughly unremarkable. Just shows you that even with benchmark products in their lineup, they can still make a dud.
S650 Mustang DFB's Detailing Garage IMG-5989f
Contact wash was via Reset, drying aid Megs HCD, windows via Invisible Glass. Tyres dressed with Carpro Perl.
The interior was filthy. I started by foaming and scrubbing the floor mats with Touch-less. After a vacuum, the plastics got wiped down with Nextzett Cockpit Premium, such an obscure product that is well worth tracking down. The leather was wiped with Bowden's Leather Love, although I had to break out the ColourLock Strong cleaner for the drivers seat, steering wheel, gear shifter and central armrest. I followed that with ColourLock Leather Protector.
S650 Mustang DFB's Detailing Garage IMG-5993f
Clean again.....................for now.
5.0ALM
Brisbane, Australia
I always forget how much extra work it is to maintain a car in winter....
...windows via Invisible Glass.
I was expecting you to be using up the BH Trace Less at every opportunity! :giggle:
I made sure I used some Trace Less on Thursday for RAV4.
It's going to take many winters to get through it, me thinks. :facepalm:
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
Bugger, missed opportunity. :facepalm:
Pro Hack - Trace-less works well on kitchen benches and stainless-steel appliances. I wonder why I know this? :giggle:
bfets
Western Australia
It's very hard to catch lightning in a bottle. With Brake Buster they certainly got it right and did.
Who would you say has best ratio of great products to duds in their entire range? Carpro maybe?
DFB5.0
DFB5.0
Australia
Mustang GT Fastback
Armour Detail Supply, Carpro, and Koch Chemie, in that order.
If we swapped that around, as in more duds than great products............................
Chemical Guys would win that contest hands down.
bfets
Western Australia
Or maybe Armor All 🤭
