Brake Fade
yeti.5oh
Bulverde, TX
2024 GT premium 6MT
24 GT Premium 6 piston Brembo brakes 1500 miles
Has anyone experienced sudden brake fade?
For me its intermittent and when it happen my Mustang needs 3/4 brake pedal depressed to stop and one activated the ABS.
no lights or warnings on the dash.
I an going to have the dealer check if the pads are glazed over but really wondering if anyone had experienced it.
stops fine 95z% of the time. Very strange..
TIA —
Frogdog1
Dixie
Replace your brake fluid for peace of mind and just because. It's DOT 4 which is hygroscopic.
That likely isn't your problem since the issue happens "suddenly" but while I'm working on brakes, I'd replace the fluid, but that's just me.
I used to do it often when I raced bikes and it can make a huge difference sometimes.
Not normal. Somethings not right. Take it in and have the system checked.
krisk
TIA —
Absolutely not normal. I’ve never experienced brake fade on the street or track in mine. Definitely get it in to the dealer to find out the issue.
ecardenas113
2025 Ford Mustang GT
I don’t think that’s normal. I have a little more miles on mine and if I hit the brakes too hard I almost eat the steering wheel. Same brembo brakes.
Fade occurs when the brakes are overheated. This does not sound like that.
Whatever it is, it needs urgent attention from your dealer.
keithwalton
N/A
2024.5 Dark horse, SLC 250d
Has the car been doing any of the braking for you before it happened ? Like adaptive cruise control or any of the emergency brake assist things? Or even the hold assist (less likely)
Reason I ask is Merc had a fault in there system where after the car had baked for itself it would leave the brakes ever so slightly still applied. Not enough that you'd notice it but enough that they'd get hot and potentially fade on a highway.
When new my car did smell of eau de brembo quite a lot even when not using the brakes that hard. Sometimes when pulling away it does feel like the hold assist is slow to let go fully
I was thinking about this, and it sounded like when the old style brake boosters lost vacuum and you had no assist.
The Mustang appears to have an electronic booster pump as part of the ABS. Perhaps that is intermittantly failing?
