B12BA error code
A.alansari
Qatar
Mustang GT 2024 PP
so I found this error when I was changing something in forscan I tried to reset the error then went to a drive and checked again and it was there anyone have a clue what is it ?
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
What I read is that the system found an error in the past but corrected itself.
Have you tried to clear the DTC and does it come back?
Yea I cleared it went for a ride and then i found it again
Anything not working?
- BLIS
- Turn signals in side mirrors
- Power mirrors in side mirrors
- Opening the windows with keyfob
- Puddle Lights
- Automatic folding side mirror function
These are the functions that your DDM controls.
Also very important, what is your battery voltage when car is off?
Check also your battery connection. It could be a loose connection.
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
- BLIS
- Puddle Lights
I will check these out when i go out but what is BLIS?
And i don't think my mirrors fold automatically unless the dealer turned it off
Blind Spot Information System.
And your side mirrors look exactly the same as all the oversea Mustangs that have automatic folding mirrors. I don't know if Ford has a third set of mirrors that don't fold in that size. My guess is that your dealer turned it off.
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
Yea i guess they turned it off
The blind spot is working
I will have to check the other things in the morning when i go out
I will check the spreadsheet as well to turn on the auto folding
Start with the battery.
JAM486HP
Is your door open when running test? I had an similar code present itself when testing with the driver door opened. Just a thought
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
Yea it is open because its too hot in here 😄
I will test this tomorrow will clear the code and retest after driving for a while again then connect while the door is closed
JAM486HP
I didn't even drive it, I shut the door, cleared it, disconnect/reconnect FORScan, gone! Hope it works for ya
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
I will try it before driving clear it reconnect while the door open
Then again while closed i hope that is the issue
@A.alansari
I had nothing to do again so I compared yours with the European cars.
Every line about auto fold or anything about folding mirrors is the same except two.
So if your side mirrors have the motors like the Europeans do, these two changes will do the trick.
It would be strange if your car has this option, but turned off by the region.
But the same was when we turned on your TSR, so I'm not that surprised if this is also some region locked thing.
I hope this works.
EUGCCNotes
7D0-09-01xxxx xx*x xx--A2A vs 2 = Autofold Enabled vs Disabled
740-02-02**xx xxxx xx--Same
740-02-07xxxx x*xx xx--020 vs 2 = Autofold vs Manual fold
740-03-05**** xxxx xx--Same
740-03-10xx** **xx xx--Same
740-04-01xxxx xxxx x*Same
720-02-01xxxx *xxx xx--Same
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
@A.alansari
I hope this works.
EUGCCNotes
Thanks a lot for this i will try it out after work here we have a lot of things turned off for no reason
