B12BA error code
GrabThatBlue
Between Canada and Europe
Thanks a lot for this i will try it out after work here we have a lot of things turned off for no reason
Yeah I noticed. But it's not your dealer who turned it off. It comes programmed like this due to the GCC importer. Every region has their own way of how the car is coded due to regulations or preferences. So don't go to the dealer and be mad about them since they are not the one who did this.
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
Can't be mad at the dealer here because there is a regional office for ford here who are controlling everything and i think they are in UAE so most likely if a GCC country have a regulations for some features they will just turn it off for all gcc cars thats what i'm thinking is happening
rbeyer
2024 Mustang GT Base
Lock status LED, to me that sounds like the little LED light that they put in the door where the manual lock pin would have been (the post you pulled up on in older cars to unlock). There's an LED (faint) in it's place, check if the one in your driver's side door is working.
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
I checked yea everything is working unfortunately I forgot my laptop at work so I couldn't try to clear the error and connect while the door is open vs closed to make sure if that Is the problem
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
cleared the error tried with the door open and closed it didn't appear
went for a ride came back tried the same thing it didn't came back as well
A.alansari
A.alansari
Qatar
Mustang GT 2024 PP
@A.alansari
I had nothing to do again so I compared yours with the European cars.
Every line about auto fold or anything about folding mirrors is the same except two.
So if your side mirrors have the motors like the Europeans do, these two changes will do the trick.
It would be strange if your car has this option, but turned off by the region.
But the same was when we turned on your TSR, so I'm not that surprised if this is also some region locked thing.
I hope this works.
EUGCCNotes
7D0-09-01xxxx xx*x xx--A2A vs 2 = Autofold Enabled vs Disabled
740-02-02**xx xxxx xx--Same
740-02-07xxxx x*xx xx--020 vs 2 = Autofold vs Manual fold
740-03-05**** xxxx xx--Same
740-03-10xx** **xx xx--Same
740-04-01xxxx xxxx x*Same
720-02-01xxxx *xxx xx--Same
just tried it didn't work so might be another thing I need to change or the mirror is different
GrabThatBlue
Yeah, might be a different mirror.
@roket
This might interest you. GCC has the overseas mirrors but they don't work like the Europeans. They don't auto fold.
