Tomasfish
St. Louis
2024 Mustang GT Convertible
I received an automatic update on April 17. It was updated to 6.2.0. I wonder why it didn't update to the 6.3.2.
I took delivery of Mustang April 20 and it had the update. Even the salesman said not all of their stock received the update.
Southpaw78
US
Acura MDX
Got my GT convertible in Sept, still haven't gotten the update yet. Just got 6.2 on 4/16.
jimsgunshop
CLEARWATER FL
2024 MUSTANG ECOBOOST PREMIUM YELLOW SPLASH
i still havent gotten it and ive had other updates so im assuming my OTA is on!!
andrew.21def
San Francisco
24 Mustang GT, 23 Camaro, 15 Corvette Z06
I got 6.2 on 4/23 and still have not gotten 6.3.2 yet. I've got OTA on, wifi paired, auto update every Monday-Thursday.
Wi-Fi has *nothing* to do with these OTAs (thus far). It has only been used once in 3 years since I got my 2021 F150, and that was a fix to correct a problem with updates coming OTA via the TCU.
andrew.21def
San Francisco
Thanks Roadpilot - appreciate it. Will mention it to the dealer when it's due for it's first service.
Yes, but be aware that the dealers won't apply any firmware updates just because they are out there (these cars are not like phones). The only way they do this is on a module-by-module basis, and that's only IF there is a problem with something and only IF someone is paying them to do it (e.g., warranty work).
Otherwise, you have to simply wait for the OTA process to bring updates to your vehicle. Not everybody gets them at the same time, either. There is no rhyme or reason, and you might get an update days, weeks, or even longer before someone else does - or vice versa.
If you're unwilling to wait, you can always buy a Mongoose-Plus VIC and a 2-day subscription to FDRS and apply them yourself, but the initial investment is ~$600 for the first time, then $53 every time you want a 2-day pass to update anything else.
jboogie1289
Friendswood Texas, 77546
This is my only issue with it. Wish they had incorporated the gear selection into it somewhere. Otherwise I love the way it looks.
What do you mean or are referring to with "Gear Selection"??
jboogie1289
I believe Fox Body doesn't have the manual gear indicator either; I'm hoping that will be the next OTA update🙏. Should be able to insert where the Auto PRNDM is.
Or somewhere else where this is suitable room. I have the Speedo on the right hand side as My Custom Mode (when it's working) is the Sport Mode Cluster set up. Or even in Sport Mode, the Speed is above the Speed Limit indication on the right side of the Cluster and the Gear Indication could be right above the Lane Keeping animation that is on the Left hand side of the Cluster.
A Software Update could incorporate such a small item but it's a Preference item and to some not necessary. And No, I don't want to drive in "M" Manual Shift mode. :cwl: :cwl:
samson
The display that tells you what gear you are in. Center of the tachometer in the "normal" theme.
S650 Mustang 60th Anniversary OTA Update (6.3.2) Released - Classic Gauge Digital Cluster Theme Screenshot 2024-05-03 132538
jboogie1289
Whoa!!! That's missing?? Now, that is something different and I haven't seen that before!
And do you have a Manual or A10??
samson
Manual. It just is not part of the Classic or Fox Body instrument cluster. It's on all the others.
I also like the mph readout in the center of the speedometer which, again, not on either of those two. I get why they did it that way but I would have preferred to have the option to turn that functionality on.
jboogie1289
Ok, I get it now. I hadn't even looked long enough to notice those things.
Billycar11
it shows all the time on the manuals
for the autos it only shows in M mode and if you tap the paddles in D
kind of wish we could make it always show
jimgt2k24
Near Detroit
I agee. An option to show the digital speed number would be nice. It is quicker to see than comparing a 'needle' to a small speed number.
