2nd Gear lockout low RPM downshift
Jon26GT
pittsburgh PA
26 Mustang GT
Hello,
I have a 2026 GT I purchased back in March.
I am at 3000miles and it is my daily driver. About a month or so ago I noticed when downshifting from 3-2 it would lock me out and this is at low speeds like 20-30mph so the rpm was only jumping to like 4k. I am not getting any grinding it just like I hit a wall and it doesnt let me in.
That is when I do it with a slight spirited movement. Not like I am doing a crazy fast downshift just a little quicker movement.
If I do my downshift from 3-2 but I go slow I have no issues with the gear change. I also never have any issues when shifting 1-2 its only on the downshift
I did the transmission mount bushing shortly after I got the car and 2weeks ago I changed the BG syncro shift cocktail and last week i did the steeda Shifter bushing mount hoping both those items would fix the issue. I feel like it happens more often after the steeda mount. Which makes me think could it be the shifter alignment somewhere. I hav emailed Steeda as well.
I am not sure if its the transmission having problems or if this is a shifter issue having some binding problems. I see alot of post of lockout at high RPM but mine is all at low rpm and downshifting
I cant say I remember having any problems with my 2012 GT back in the day.
Thanks
GrabberB
Don't take this the wrong way but........ Not a good idea to throw changes in the mix when attempting to fix an issue. That only complicates matters because the issue you describe doesn't need aftermarket products to fix. Improvements can be made, bad timing here. Fix or address the issue at hand then make changes. Return back to stock (everything) including fluid. Let the dealer and warranty cover any potential issues.
If you take it in under warranty as-is chances are high they'll send you on your way. They'll likely say 3000 mi. and the issue started when? Before you can answer, they'll likely say oh i get it after your upgrades.
My 2 cents..... rewind, start over and warranty.
Hope you get this figured out!
Jon26GT
pittsburgh PA
26 Mustang GT
I cant make the mount change back as I had ford put it in for me when I took it in last week for the wiper recall and use one of my free oil changes and they did the mount swap for free.
I am assuming they tossed the factory mount as they didnt give it back.
There was a week in between the mount and fluid and it was still doing it after the flud change so that was already tested to see if it fixed and it didnt so the mount was done the next week and it didnt make the change so things where not all done at the same time to verify if one fixed it or not.
GrabberB
Do you have rev. match enabled? If not, enable and see if you notice a difference.
I assume this issue was not present from day 1 - correct?
If you use the same Ford Dealer for warranty it would be bold of them to call you out for whatever they installed for you. Let the Ford Dealer test drive and check to see if they see any issues (Warranty Check).
I have a 2024 GT PP with 6-speed manual paired with 3.73's. I perform 3-2 downshift at a higher speed/RPM. I assume your Mustang has 3.55. Seems like you'd want to downshift sooner than I do. All my driving is spirited, very spirted so there is that.
Jon26GT
pittsburgh PA
26 Mustang GT
I have always had rev match on.
it did not do it from the get go at least I don’t remember. Maybe I didn’t do many 3-2 shifts. noticed it was happening here and there about month-2 months ago.
the car has never been really driven hard. I honestly am not sure if I even have taken it to redline yet and I have never done any hard shifting on it.
it does have the 3.55
Sorry if I missed it, but was the car doing this before the aftermarket stuff?
Jon26GT
pittsburgh PA
26 Mustang GT
Yes, I noticed it happening about a month or 2 before I did the fluid or mount
Jon26GT
pittsburgh PA
26 Mustang GT
So, on my way to work this morning I did a little testing.
I did 2 pulls one was a 1-3 and the other a 1-2 and it shift perfect doing high rpm shifting. I am still getting the lockout going from 3-2 if I move my hand little quicker. if i have a ore relaxed slow movement it goes right in. I am thinking it is the shifter and if I upgrade it would probably go away. I still am going to take it to ford but It seems fine the way it did the 2 pulls at High rpm shifts
Jon26GT
pittsburgh PA
26 Mustang GT
Ok I am starting to think it is me trying to drive it like my old 22 SS 1LE and my previous GR Corolla.
This trans doesnt seem to like the quicker movement and slowing down my downshifts by just a hair it solves all the issues. I can still go quick but had to adjust to what this seems to like.
The last 2 cars they didnt mind faster moving downshifts and went into gear alot smoother.
Im confused why you are doing pulls and testing 1-2 and 1-3 shifting of the issue is going from 3-2. What rpms are you going from 3-2 at? And is it a full lockout, or just hesitation to go into 2nd? I can't decide if this is an actual problem or just user error.
Jon26GT
pittsburgh PA
26 Mustang GT
i was doing the pulls to see if the transmission was having any issue on hard high rpm shifting as well with 2nd gear.
I was going 3-2 around 20-30mph like 2500rpm and it was a full lock out it wouldnt go in at all. I had to go again. after adjusting the movement i found the sweet spot this car seems to like and it seems to not have an issue. I just have to move a little slower than previous cars I had when downshifting.
in the end I figured it out and dont have the issue now
How did you adjust the movement? Its either locking out or it not. 🤷🏻
It sounds to me like synchros are slow to match gear speed when shifting quickly and that is stopping the shift until the teeth line up. Although this should not happen with rev matching, unless rev matching does not work at low rpm?
I'd try it with heel and toeing to see if there's a difference.
