2025 GT: Two Months and 4k Wonderful Miles
Deleted member 63380
Guest
Very nice car. Which spare tire did you get...made by whom? I need to get one. THX...FD
I seen a lot on Ford parts, and it was $390, I believe. Not sure if it will fit Brembos, if you have them. But it's about $100 cheaper than aftermarket. Also is a complete kit. Im going to have to order a couple. Unless I order aftermarket wheels. I may be able to use my stock 18s as spares, if they fit into the wheel wells.
The below Pioneer on Amazon. Install was easy. Yes, plug and play with pigtails and just a slight adjustment. I also added the Polyfill. I have included the link to instructions that made it easy and straightforward.
https://a.co/d/gPj7Jpg
https://www.mustang6g.com/forums/threads/b-o-10-sub-replacement-guide.148813/
Thanks. I did find this video after posting. He's used the exact same part. Looks like the only downside is breaking the clips on the ring, and getting the new speakers holes to line up.
DT-GT
DT-GT
I used that one. Yep, good guidance.
DT-GT
DT-GT
No advice. He shows it well in the video. Take it slow and cautious and it goes well. It is a big improvement over the cheap OEM sub.
Any advice about the clips and holes? Or did he do a good job in the video?
Guest
Seal it tight. Use that grey foam with one side of sticky stuff, and apply it to the rear of the speaker. It'll be air tight.
Just ordered everything online. It arrives Saturday. 😎
DT-GT
DT-GT
On Amazon:
https://a.co/d/8umYOJ1
I did not like either of the mounts that came with it. I used a dremmel to grind off most of the plastic mount on the back of the charger. I then used string double/sided tape to attach it to the removable pad by the USB and 12V plug at the front of the console in front of the gearshift lever. Was careful to not allow the tape to block the openings where the air is pulled into the device. I used a small 12V to USB-C plug to power the unit. Charges my iPhone 16Pro well and does not overheat. Very pleased after using it for about 2k miles.
What wireless cooled phone charger did you install?
72Skiddoo
Down State Illinois
2025 Mustang Ecoboost Premium Convertible
On Amazon:
Hi DT-GT. It’s been a while. Will you share a photo of your wireless charger installed.
DT-GT
DT-GT
Here you go. The blue lights up when it’s powered on — it is covered when my phone is there.
At that point why not just plug the phone in?
DT-GT
DT-GT
I like the wireless charging when I can use it. Easy to just place the phone there and it gets charged! I had an earlier iPhone where the charging plug on the phone broke after so many uses, so I generally use wireless charging unless I need a wired data connection.. The USB-C plug seems stronger and an improvement.
