2024 S650 Mustang EcoBoost front suspension clunk/thump over bumps — need help diagnosing
Jesu2323
2024 Ford Mustang Ecoboost
Hey everyone, I’m looking for some help diagnosing a front suspension issue on my 2024 Mustang EcoBoost (S650) base model.
I’m getting a clunk/thump from the front suspension when going over bumps. The noise happens consistently over rough roads and smaller bumps, not just large impacts.
I’ve already replaced:
  • Front sway bar end links
  • Outer tie rod ends
The car does not have:
  • MagneRide / Magnetic Damping
  • Performance Package
I’m currently suspecting the upper strut mount/bearing (FR3Z-3A197-B) because the symptoms seem consistent with a strut bearing or mount issue, but I wanted to ask if anyone else with an S650 has experienced this.
Questions:
  1. Has anyone had a similar front suspension clunk/thump issue on a 2024+ Mustang?
  2. Was the upper strut mount/bearing the cause?
  3. Are there any common S650 front suspension issues I should check before replacing parts?
  4. Are there any specific tests I can do to confirm the strut mount/bearing is bad?
Thanks for any help. I’d appreciate any suggestions before tearing into the suspension.
jloops
2025 Mustang GT Premium
I had a clunking/ rattle on my 25 GT that was one of the upper strut mounts which was replaced under warranty.
The tech sent me a video where he was using a pry bar to gentle show how one side had play and the other side didn’t. Sorry I looked but don’t have the video anymore.
Fruitstang
2024 Mustang GT Convertible
Sounds like the upper control arm.
Had similar symptoms on my S550, there was minimal, very hard to find play in the ball joint.
Marked with yellow chalk:
S650 Mustang 2024 S650 Mustang EcoBoost front suspension clunk/thump over bumps — need help diagnosing IMG_20180208_184824
Replacement is relatively cheap.
Had to replace them twice within 80,000 miles, but always depends on the road conditions.
