2024 Mustang GT Alternator Amperage?
DarkkMatter
Virginia, USA
I've been trying to track down what the stock alternator amperage is for the S650 style Mustang, and it isn't easy, but I think I have found it for the '24 Stangs at least which should be the same for the '25.
Searches, AI, Dealerships, and Ford istelf were a bust, but then I got the Ford Part #, did a search by that and luckily one site showed the sticker that I think shows the amps, which is 190.
You can see the pics here: https://www.tascaparts.com/oem-parts/ford-alternator-assembly-pr3z10346b It fits the 5.0 trims. Assuming that 190 on the sticker is the amperage?
highvoltage
NorCal to SoCal
2024 Mustang GT 6spd
Why exactly you trying to get that info? Audio stuff?
I believe that 190 is correct... seems I've seen that elsewhere.
DarkkMatter
DarkkMatter
Virginia, USA
Yeah, I'm putting in either a 1000 or 1,200 watt amp for two 10" subs. Just want to be sure I'm not exceeding too much amp draw. I know the stock systems draw a certain amount.
Abilor
Albany, NY
In exact same boat, 1000W for 2 12s at a 2 ohm total draw, 90A load. 190A seems like plenty of room. Hoping Big 3 are already 4ga too then.
https://performanceparts.ford.com/part/M-8600-M50ALTD
we now have verification that it is 190A. GT and DH share this same part
given that the fuse for the alternator on the BCMC/battery junction box is 275A, logic states that the wiring is rated for that or above, because there's no point to a fuse if the wire fails before the fuse does
