10R80 temperature
csolas
Miami FL
2019 Mustang GT
hello folks,
i am so disappointed, some pulls and spirited driving and my temperature goes to 245 on the trans. the car goes into what appears to be limp mode until trans cools down. how come ford sells you a mustang like this? you cant drive it like is meant to be driven? anyone with same complaint?
2025 base GT 10R80
thank you.
csolas
csolas
Miami FL
2019 Mustang GT
Unfortunately you need a trans cooler
so I paid 50k to then have to buy an additional part for my car to do what is supposed to do from the factory? not happy about this.
I constantly hear I can't understand why my transmission, engine etc. is overheating when I am just driving it in a "spirited" manner or what I am doing is "normal". Neither term has any meaning whatsoever. as there are no meaningful empirical data points to those adverbs/adjectives. Even passenger cars have towing options for just towing a jet ski that involve additional cooling. How many RPM are you shifting at? How many times do you do that in succession? What is the ambient air temperature, the humidity? If you want to drive this car like a road racer then start with auxiliary transmission coolers - an inexpensive solution. If you are really flogging it (and I suspect many owners are) then increase your engine cooling capacity too. - again not that expensive. This is basic physics as in thermodynamics not rocket science or voodoo magic.
"pulls and spirited driving", while in Miami, FL, when air temps are 85 F / 30 C at sea level.
https://www.mustang7g.com/forums/threads/normal-a10-transmission-temperatures.166445/
Ford had different objectives when they defined their offerings. A PP or DH might have suited your driving style and environmental conditions better. A dedicated trans cooler, larger than any factory unit, would be a great mod.
I did not study what's on offer for the S650, but Mishimoto is one company of several that get good reviews for their products. The following link shows the differences between the stock S550 PP unit and something they designed.
https://www.mishimoto.com/engineeri...ansmission-cooler-rd-part-2-prototype-fitment
I'm also including some 6G track references, to give you some ideas what can be done to mitigate heat when laying into one of these cars.
https://www.mustang6g.com/forums/threads/the-big-fat-track-car-cooling-thread.53695/
https://www.google.com/search?q=mus...HcqIN1kQrQIoAnoECB0QAw&biw=1462&bih=742&dpr=2
with yours being a base GT, you very likely dont have the auxiliary transmission fluid cooler. yours probably has the standard cooler, which only uses the coolant, and if your trans temps are that high, your coolant temps are probably pretty high too, so thats not doing much of anything. the GT performance package changes it so that there are lines going to a heat exchanger between the radiator and condenser as well. its not that Ford doesnt want you to drive a certain way, its that Ford expected people who get the transmission fluid or oil really hot would get the GT performance package, as it has dedicated heat exchangers for those fluids. if you look at the gauge for trans fluid temp in the My Mustang menu, you will see that the danger zone for the transmission fluid is about 260F if i remember right.
unfortunately, at this time it looks like nobody, not even Ford Performance, makes a kit to retrofit that heat exchanger, and it might be more worthwhile, especially if you expect to do spirited driving a lot, to trade in for one with the GT performance package, which also adds Brembo brakes, a bigger radiator, an auxiliary oil cooler, a strut tower brace, and the drift brake.
off topic, but what happened to your 2024 GT PP manual to make you get a 2025 GT base auto?
Germansheperd
2025 Dark Horse
hello folks,
2025 base GT 10R80
thank you.
It is not “how come Ford sells you a Mustang like this”, it is you bought the wrong Mustang from Ford.
Trade it in and buy a PP or a DH like you should have in the first place and problem solved.
1. Define "spirited pulls"
2. What temperature is your environment?
you should be able to go 0-150 in a stock Mustang GT without overheating....
csolas
csolas
Miami FL
2019 Mustang GT
guys, thank you so much for all the info you have all provided. this helps me understand a lot better. i do disagree with the fact that some of you mentioned I should have bought the PP. in my opinion a company must research and test their product before delivery to market happens. even the non PP should not heat up like this when doing a couple of passes.
79 degrees at 82% relative humidity. (night time)
in drag mode, both me shifting or the car shifting it takes about 6 full throttle launches for trans to reach 245 degrees.
thank you and have a good day.
Allanrock59
Quebec city Canada
Fusion Titanium 2013. Ecoboost 2024 on order
Does that also apply for the ecoboost with the PP. I have a 2024 EB with the PP
ecat does list the EcoBoost as able to have that cooler too, but PM me your VIN and i will check for sure
There was another poster complaining of the same thing in another thread. He was driving the car like a bat out of hell doing WOT pulls to 150 in Manual mode, even though he said he wasnt "beating on" it Lol. So I think "spirited" has different meanings to different folks.
6 full throttle launches in drag or manual model on a 10R80 will definitely heat up the trans. Even with the PP I'd expect to see temps above the norm. This is a 10 speed auto after all. If you are going to do this on the regular, let the car cool down after a couple pulls. If you dont want to do that you probably should have opted for the PP or a manual trans.
