Windshield Washer is Very Weak
Bbeckers24
2024 Mustang Ecoboost Premium Convertible
I have the delay issue, but the spray after it starts is fine. I am wondering if Ford just did not include a check valve, and the line bleeds back down every time? I might try to install a check valve and see if it solves the delay for the spray.
Doug Watson
I had a pinched line so once I fixed that the stream now is good.
Doug Watson
Where was your line pinching?
If you have the 2024 it should be ok but in my case it was pinched around the hood strut. 2023 and below if you put on aftermarket struts then you need to relocate the line. Just drilled another hole in the hood and used the exesting push pin.
4koptiks
Kittywoo2
Ahh okay, mine is sputtering and taking a second to spray like op. I do have a 24 but okay I’ll have to check as much of the line as I can and see if that’s the issue. Hopefully it’s not the pump.
Frogdog1
Dixie
Mine is as it should be. In Georgia, you're going to need it to work right.
Mine would be at my dealer to get it fixed. My dealer would fix it too. Knock on wood, but so far, it is the best dealer I've ever dealt with. I also just prayed that my list of problems would have that one as the most serious problem. I'll get there and you'll get your squirters fixed.
GrabThatBlue
Between Canada and Europe
Sorry to hear you are having trouble with your stream... unfortunately, I may never know about the stream on mine as it never gets wet.
You never used your washer when driving?
So many times when big bugs hit and stuff.
Just don't be the Jackass who uses their washer fluid while driving down the road. You might as well squirt a hose on all the people behind you.
