Window Trim Issue
chris861
AL
Foxbody
Anyone experienced an issue with fitment of the window trim to the a pillar? I noticed this on the passengers side of mine. Driver side looks fine. I'll be taking it to the dealer for the BCM recall and the luggage compartment tsb, but thought I'd see if anyone had the same issue.
S650 Mustang Window Trim Issue 17227
S650 Mustang Window Trim Issue 17226
Timry2
Fresno, Ca
Yes, I used a plastic spatula to lift it back into place. I didn’t notice any permanent creases in the molding. No leaks either
I have not seen that. It looks like the seal is just not seated correctly.
chris861
AL
Foxbody
Thanks! I was tempted to do the same, but figured since it's under warranty.... The dealer would probably just do the same thing though.
Timry2
Fresno, Ca
I live in a hot climate so it just conforms to the body of the car. Happens when i wash her.
S650 Mustang Window Trim Issue IMG_3858
S650 Mustang Window Trim Issue IMG_3857
S650 Mustang Window Trim Issue IMG_3856
cal5mcd
So Cal
24 Mustang GT Prem, 1969 AMX, 2012 Ford Raptor
I have the same issue I posted months ago, tried credit cards overnight and everything else I could think of. Still the same way. I’m going to have the dealer figure it out. To me it looks like the window is not quite installed deep enough….
S650 Mustang Window Trim Issue IMG_2650
chris861
AL
Foxbody
Yea I tried repairing mine using some plastic trim tools. Even after folding the lip out, it was still a bit kinked and didn't look right. I'll have the dealer fix it once I get the courage to schedule the BCM recall. I just don't trust others to work on my things šŸ˜…
kenkroop
new jersey
2018 gt a10 2024gt a10
I have the same issue on my 24. Scheduled for service. Dealer says trim and glass are one piece.Part is back-ordered.
ZXMustang
tooner
2025 ESS G3 Mustang GT
Bump. My new 25 has the same defect on the passenger side front window leading edge. Its all tucked in and jagged looking. I was able to pull it out but the edge of the rubber seal ripped and it looks horrible. Brand new 25. WTF ford. I didnt see it for a few days after purchase being on the passenger side and that side is close to the garage wall. Damn it, I would have had them fix it before I took delivery.
Anyone else get this fixed?
Will2
'26 Mustang GT
My brand new '25 had chips down to bare metal on the A-pillar by the window trim, nearly covered by the rubber trim. I suspect from when they installed the trim at the factory.
In the touch-up process I found that the window trim will reshape itself after some heat. You could try running a hair dryer along it for a while to see if it settles out.
