Whipple Calibration and Idle Surging
North Carolina
I recently installed my Stage 1 Whipple kit on my S650/6spd manual. Everything went very well during install, checked and double check everything for leaks, bolt torque, gaskets were installed correctly,etc. Cranked the car up for the first time after loading the tune, she ran! When the car was stock, it idled at a near perfect 750 RPM all the time. Now i notice after the car is fully warmed up it will idle at 800RPM. Sometimes when down shifting, coming to a stop then putting the car in neutral, the idle will dip down sometimes to around 760-770-780 RPM and then surge slightly above 800RPM...say like 810-820 RPM before eventually idling back down to 800RPM. This all happens over a 5-7 second window. Ive checked around the throttle body for vacuum leaks. Also checked around the blower itself and wasn't able to get the engine to climb in RPM at all.
Note: I have driven the car at least 300 miles so far with the Whipple on and im pretty certain it has left the "relearn" window
My first thought was maybe this a normal characteristic of the blower or something having to do with Whipples calibration settings.
My 2 questions:
1.) Has anyone who has installed this gen 6 whipple noticed a change in idle speed over stock?
2.) Do i have a vacuum leak somewhere?
Any insight here is greatly appreciated. Thanks!
Loucas
Tamarac, FL
2021 Mustang GT PP Grabber Yellow
Tune or a vacuum leak issue. Also could be normal. From what I've read it's not uncommon for the car's idle behavior to change after a Whipple install.
GhastlyTT
Hampton, VA
I checked mine for ya. No surging, but my idle fluctuates between 780 and 820 when the throttle is closed. I do find that engine braking has been reduced a bit. Revs don't fall as quickly as before.
DeathByRedHorse
North Carolina
Yep that's exactly how mine is doing. I guess what I meant by surging is exactly what you said in that it fluctuates between that RPM range. Thanks for the info...maybe this is indeed how the whipple cal is meant to be for these cars
GrabberB
@DeathByRedHorse - Old thread. maybe still relevant? I wonder if the idle/RPM fluctuations you experienced last year were/are related to the recent Whipple Calibration hold issue.
Curious if your issue self resolved? Also curious if you updated to the new calibration,
DeathByRedHorse
North Carolina
I have a manual car, those calibration updates that whipple rolled out were for the 10spd auto cars no? i didnt see any for 6spd
How’s your plugs (spark)
Billycar11
you have to reach out to whipple for the updated tune its not posted anywhere
you need to have already setup your req file with them or you will have to start fresh if a shop did it for you
