Weird burnt rubber smell on delivery
SoggyBottomBoy
US
N/A
Yo! Just wanted to check with the forum to see if anyone had ideas. This is my first ever time taking delivery of a brand new car, so not 100% what to expect.
Whenever running my 24 GT I notice a bit of a burnt rubber smell, and it tends to be just from the passenger side of the vehicle. I read around online and people say new cars have some weird residual burning smells for a bit after getting them that need to be burnt off, so just wanted to see if anyone else had the same thing or if it may be something else.
To clarify: 24 GT, Manual, active exhaust
Thanks!
DukeCLR
Vermont
I have had sever new cars and there was never a burning rubber smell. There is a chemical smell that come form some of the component gassing out but they don't smell like burnt rubber, that comes form doing burnouts.
SoggyBottomBoy
US
N/A
Maybe I'm misinterpreting the smell then? How long should I give it before having a shop check it out?
Maybe the clutch is being broken in. It might have a slight brake pad heated smell.
SoggyBottomBoy
US
N/A
Could be it. I figure I'll give it a week and if still there take it to Ford. Great thing about warranty is none of this needs to be stressful
Dena
Phoenix AZ
I am not sure about what they are using now but normally brake and clutches smell like ozone/electrical smell. Believe me, I have had good doses of it going down the grape vine. Some of the truck drivers get going too fast and do a number on their brakes on the way down.
I know better and always gear down and on newer cars use the cruse control to provide additional braking. Most the time I don't need to touch the brakes.
Carter1776
Indiana
2024 Mustang GT Atlas Blue
I had a burnt smell from my GT PP A10 when i took delivery but i believe it was the exhaust getting hot and burning all of the appropriate oils/residues off from under the car. Only lasted the first 2 days before it was completely gone.
I had a wide variety of burning smells that first ride home, yes. Assembly lubes and sealers. New, unweathered materials. Countless hands all over the mechanicals during assembly, shipment and final inspection.
The burning smells occurred while bringing the car up to its operating temperature for a sustained period its first time. I don't remember those smells lasting more than the first or second drive.
You can also run the A/C, defrost and heater with the fan turned up. Just for a few minutes. Later, clean the insides of your windows well.
You've probably already done this, but you can do a good visual, under hood and underneath. Could be one of the shipment bags, tags or trash stuck near a heat source. The first several drives, I always did a visual anyway when returning, to ensure nothing was leaking or going awry. But yes, if it continues, return to dealer for a deeper investigation.
Congrats on picking up the car. :like::clap: Enjoy the ride. :rockon:
  • Like
Reactions: Zig
SoggyBottomBoy
US
N/A
I did find a tag still on the engine badge, thought maybe it could've came from that or something else as well. Will find out soon enough!
Tires, hoses, electrical lines, exhaust, cats, and since a manual, clutch. Location based upon intensity although wafts do follow their own path.
for the most part the only item that will get hot enough to melt rubber/plastic will be the exhaust. Yes, clutch will smell but unless you’re really abusing it shouldn’t be a problem (btw may more or less smell like burnt brakes - like when a trucker burns his brakes trying to slow his rig cause, well anyway you get the idea).
i’d let her cool and then do a thorough exhaust inspection, over under under over, feel all the parts you can’t see just to make sure some road debris (rubber pebble) didn’t find its way onto the exhaust.
if everything checks out, nothing obvious rubbing or laying against something that could cause it to melt, I’d then probably go for a nice leisurely drive for about an hour (at least 30 minutes without turning off the engine). All while keeping an eye on the gauges regarding temps and pressures.
Any engine / exhaust heat cycle related smells should be noticeable after 30 mins and may help direct you toward the area to investigate once cooled, rinse and repeat if smell continues (or back to the dealer and let them find and explain).
just thought of it as typing this and I’m almost wondering if it’s ebrake on the passenger side but that shouldn’t really smell like burnt rubber.
but then maybe you’re just a tad to aggressive and the burnt smell is the right rear tire…
SoggyBottomBoy
US
N/A
Definitely no aggression. the smell happened in a 2 minute drive from a parking lot they dropped it off at to my house, without leaving second gear.
papaD
canada eh!
I did have a smell after I picked up my car.
The problem appeared to be associated with the right pedal coming into contact with the floor when the traffic lights turned green...
sorry i couldn't help...
T-Tom
GA
2021 Mustang GT - Carbonized Grey Metallic
I had this same thing happen on my brand new manual '21 GT (and same as you, first ever new car so I had no idea what to expect). This smell stayed around for about 2 weeks and I was worried it was my clutch or a weird issue with the brakes so I took it to the dealership. They took the exhaust off and found stickers from the factory that had burnt up and smelled. The technician even scraped them off and told me to give them a whiff and sure enough it was the exact same smell that kept happening. He was kind enough to check the full exhaust and remove any more stickers (there were 3 total).
Good luck! Hope your fix is as easy as mine was
SoggyBottomBoy
US
N/A
I had this same thing happen on my manual '21 GT. This smell stayed around for about 2 weeks and I was worried it was my clutch or a weird issue with the brakes so I took it to the dealership. They took the exhaust off and found stickers from the factory that had burnt up and smelled. The technician even scraped them off and told me to give them a whiff and sure enough it was the exact same smell that kept happening. He was kind enough to check the full exhaust and remove any more stickers (there were 3 total).
I found 3 stickers in the actual engine bay, removed them, wondering if that was involved
