Transmission Fluid Change
@Iceman28.... good catch - and - you are 100% correct - I definitely did NOT have an 10R80 in my 2014. My comment was intended to say ...... IF IF IF the tranny dip sticks are the same then to be REAL careful as in my 2014 you had to remove the "plastic-like" cap/nut and it had a small dip stick attached to it. It was easy to break (and many techs/owners did) AND if the dip stick part broke-off it fell into the tranny - an oh $hit moment for sure! Also, if I remember correctly to check the level you had to do it hot, on a totally level surface, cycle through the gears, then rest the dip stick part on top of the hole.......my suggestion was - IF IF IF the 2024-2025 10R80s have the same type of tranny dip stick arrangement there are a lot of things that have to be done right. Guys with home lifts can do this no sweat but I sure as h3ll wouldn't want to do this on my garage floor - I'd go to a dealer. Cheers MT
