SVE Jack Pads Now Available For 2024 Mustangs - Save Your Undercarriage!
Late Model Restoration
2015-24 MUSTANG SVE JACK PAD KIT COUPE
Buy Now: https://lmr.com/item/SVE-2024JP-K/sve-mustang-jack-pad-kit-2024
Install Video:
S650 Mustang SVE Jack Pads Now Available For 2024 Mustangs - Save Your Undercarriage! sve-mustang-jack-pad-kit-15-24-coupe_de359b8
SVE Jack Pad Kit
Safely jack your 2015-2024 Mustang coupe up without damaging the pinch welds or frame rails with SVE's billet aluminum jack pad kit! One of the most common areas to lift your Mustang is via the pinch welds, located below the rockers. After numerous improper attempts of jacking up your Mustang, the pinch welds can become warped or crushed. To prevent this common issue, SVE is proud to offer this premium, solution-based kit to ease the maintenance of your S550 or S650 and provide a safe jacking point, all while protecting the factory pinch welds in the process.
S650 Mustang SVE Jack Pads Now Available For 2024 Mustangs - Save Your Undercarriage! sve-mustang-jack-pad-kit-15-24-coupe_fb76e034
High-Quality Materials
Designed and manufactured in the USA with the highest quality materials, SVE's jack pad kit features a billet aluminum construction with an 8mm opening between the side gussets in order to provide the structural support needed to evenly disperse the weight of your Mustang onto your hydraulic jack. Each jack pad has a deep groove and bolts to the underside of the chassis, making it easier to position your jack. Completed in a black anodized finish for the ultimate corrosion resistance, these jack pads are engraved with SVE's signature logo for the ultimate stamp of approval for this problem-solving solution! SVE took it a step further to have "JACK" engraved on the outward-facing side to make it easier to identify the proper jacking spot.
BENEFITS
  • Protects Factory Pinch Weld
  • Provides Safe Jacking Point
  • High Strength Holding Capacity
  • Made In The USA
FEATURES
  • Billet Aluminum Construction
  • Bolt On Design
  • Black Anodized Finish
  • Engraved SVE Logo
WHAT'S IN THE BOX
  • (1) Jack Pad Set
  • (2) Rear Pad Bolts
Trap
Alberta
2013 Mustang Boss 302
The pads are a great idea, but I still think I would prefer Jacking Rails
dbroush7
2024 Ford Mustang EcoBoost Premium Performance
I just installed these this afternoon. I wanted a way to minimize the risk of shops damaging my pinch welds (or something worse) since there are all these belly trays obscuring things under the 2024 model. The SVE/LMR pads seem to be great (easy installation and appear high quality) but I'm going to allow the threadlocker to cure for 24 hours before I use them. I'm doing an oil change tomorrow or Saturday, so we'll see how it goes!
