Ford Performance 2024 Mustang Oil Separator Kit - Now Available
jimbo67
24 Dark Matter, PP, NPP
Akin to using premium fuel
Right, 87 octane is the minimum, why buy a vehicle with engine like this, and spend all that coin and use low octane fuel?
Farmer Fran
2024 GT Premium Vert
Ok, I'm gonna ask the dumb non-mechanic question here. Is this really necessary? Did we buy a car with an engine that will destroy itself by design?
What am I missing here?
Oil catch can is in the same realm as
what oil to use
what weight oil to use
87 or 93
Auto or manual
You will get as many + as you will -
jimbo67
what oil to use
87 or 93
Auto or manual
In reality it comes down to maintenance, every engine is different. But maintenance is key! Maintain you vehicle it will give many smiles per mile.
DarkMatterGrey
Scottsdale AZ
Anyone buy this kit and have any oil in the driver side?
DarkMatterGrey
Scottsdale AZ
I have this, but just installed after winter storage. Very complete kit I cheated though and let dealer servicing the car install ($60).
Probably a good idea if in warranty (if that matters to you) to have them install it. I am trying to evaluate my options. $600 is a bit steep for both sides (passenger/dirty and driver/clean) especially if the driver side is always empty. I'd say driver/clean side is a good idea if you have boost, but they make another part number for that M-6766-A50DSC vs M-6766-A50D. Also, if there's a way to see if the M-6766-A50D is similar enough as the M-6766-A50A for passenger/dirty (and maybe buy just new hoses if the AOS body is the same). Or just go aftermarket, JL OSC $170 or UPR $200 where I can add a clean side for $150 in the future if the Gen 4 Coyote without boost fills up both reservoirs.
https://performanceparts.ford.com/part/M-6766-A50A
https://performanceparts.ford.com/part/M-6766-A50D
https://performanceparts.ford.com/part/M-6766-A50DSC
Side by side pic...
S650 Mustang Ford Performance 2024 Mustang Oil Separator Kit - Now Available 1746297838549-zc
Update, may have answered my own question, only thing in common is the AOS Body in the first line below. The hoses, brackets, and nuts/bots are different. The hoses don't show they can be ordered separate except for the S550 kit.
S550 Kit contents:S650 Kit contents:S650SC Kit contents:
1x CM-6766-A50A Oil separator1x CM-6766-A50A RH oil separator1x CM-6766-A50A RH oil separator
1x CM-6K817-M50A PCV tube1x CM-6K817-M50RI RH inlet PCV hose1x CM-6K817-M50RI RH inlet PCV hose
1x CM-6K817-M50B PCV tube1x CM-6K817-M50RO RH outlet PCV hose1x CM-6K817-M50SCRO RH outlet PCV hose
1x CM-BRKT-M50A Bracket1x CM-BRKT-M50R bracket1x CM-BRKT-M50L RH bracket
1x W520412-S437 10mm flanged self-locking nut3x W520201-S440 M6 nut1x W717798-S437 M6 bolt
1x HL3E-6C291-BA Cam Cover stud bolt2x W701571-S450 studbolt2x W701571-S450 studbolt
2x W520100-S437 8mm self-locking nut2x W520201-S440 M6 nut
1x CM-6766-M50D LH oil separator1x CM-6766-M50D LH oil separator
1x CM-6K817-M50LO LH outlet PCV hose1x CM-6K817-M50SCLO LH outlet PCV hose
1x CM-6K817-M50LI LH inlet PCV hose1x CM-6K817-M50SCLI LH inlet PCV hose
1x CM-BRKT-M50L bracket1x CM-BRKT-M50SCL LH bracket
