Smaller Diameter Tires to Boost Final Ratio
RBGT
BC
S650 GT Premium, 6 spd
Looking at the MT82 vs Tremec ratios, its unfortunate that the gears are taller in with MT-82.
Ordered the manual non-PP GT with 3.55 gears with the Brembos.
Besides the fender gap (that can be lowered and speedo) would it be a bad idea to get smaller diameter tires?
Stock = 255-40 with 3.55 gears
275-35 Final ratio = 3.61
285-30 Final ratio = 3.73
RBGT
RBGT
BC
The PP tires is actually larger than the stock rear tire and lowers the final ratio a bit.
PP rear tire
275 40
PP effective ratio is = 3.65 compared to stock
RBGT
RBGT
BC
The dark horse on the other hand with shorter 315 30 tires and 3.73
Has an effective ratio of 3.81
RBGT
RBGT
BC
Swapping out the rear axle is a pain and a couple of local mechanics said they wont touch it as it will void the warranty and they don't want to be liable.
I would want the warranty myself.
RBGT
RBGT
BC
S650 Mustang Smaller Diameter Tires to Boost Final Ratio Screenshot 2023-08-03 101338
RBGT
RBGT
BC
Drove the 3.73 Mach1 and it didn't feel snappy.
Below 3500 rpm, it could be any regular car and really comes to life 4500 and up.
I see folks with the S550 switching to 4.09 gears.
agreywolfe
Oklahoma
Does that show about a half foot less per rotation?
Yes, about 4.1 inches less, which equates to about .05 mile less for ever 1 mile on the odometer or about 5 miles every 100 as can be seen with the speed chart under the tire images
RBGT
RBGT
BC
Car is lowered 0.6 inches.
Braking should be better.
Rotational inertia decreased in tires.
Smaller sidewall will feel bumps a bit more.
Fuel economy will suffer.
RBGT
RBGT
BC
Speedo will be off by a few MPH, not the end of the world.
70mph on the speedo will be 67mph in reality.
Acceleration should be more aggressive in all gear instead.
agreywolfe
Oklahoma
Yeah I worded that badly, the point I was trying to get across was for every 1 miles worth of rotation the larger tire does, the smaller one only completes .95 miles, so you'll need to push the tire that 5% longer to achieve the goal of the larger tire.
RBGT
RBGT
BC
Why not just get the PP?
$5000
Tries supplied are not really "performance"
Wheels not very nice, quite skinny, and heavy
"Drift" brake is a gimmick (to me)
Don't want a rear wing - prefer the clean look
Missing out on the front springs + K-brace (don't seem expensive to add)
Already got the brake + AE
RBGT
RBGT
BC
Yes, main reason would be to increase the force to the ground and up the effective torque.
Ideally, the Tremec + 3.73 would be better but then its the Dark Hor$e
