Rear suspension clunking
codyh
california
2024 mustang gt
Hey guys, first time posting on here, having a rear clunking noise I cannot solve and was hoping for some help / guidance.
I installed steeda’s dual rate lowering springs, with ford track shocks / struts. Got the car aligned and it’s right on spec and the noise was there prior. Every time I hit hard bumps, speed bumps, uneven surfaces it has a light clunk sound that seems to come from both sides it seems like near the upper rear end. Fwiw I have steeda’s stop the hop ultimate kit, I just replaced the rear sway bar with rtr, I did adjustable end links and I went and got near oem upper rear shock mounts and the sound is still there.
Alan Applegate
Roswell, NM
I had that too. Turned out to be one of the rear seat latches. Sure sounded like the rear end!
codyh
california
2024 mustang gt
I have a rear seat delete in my car. Otherwise I wish lol. Mine has all the latches removed.
codyh
california
2024 mustang gt
Those should be the correct bump stops for a lowered car. Were all of the suspension bushings torqued at ride height?
Yes. I clocked them 2x just to be safe. I took the rear shocks off, inspected them looked ok. Re torqued them, changed to new oem rear mounts and the sound is still there. Only thing that seems weird is the springs seem to have different tension on them. One of them is looser than the other but both are properly installed and seated.
highvoltage
NorCal to SoCal
2024 Mustang GT 6spd
something ain’t right if that’s present
Sounds like you covered the common stuff... with an obvious difference in the spring size/tension, I may suspect a spring issue. Maybe time to contact manufacturer.
codyh
california
2024 mustang gt
I wrote them today to be safe as well
codyh
california
2024 mustang gt
Yeah on jack stands one spring is tight the other isn’t as much. You can’t literally move it but you can see there’s a difference in “ tension “ I would say.
n_123
2024 GT
Anything get resolved here? Having the same issue.
