Rear Differential Temp Sensor Harness
Timry2
Fresno, Ca
2024 Mustang GT, Dark gray matter, 2020 F150 XLT Sport, magnetic
TPS Motorsports never shipped so I canceled the order and built a custom set up. I have a PP, so all i had to do was buy the harness pins and add a couple of wires to make it work.. the hardest part was finding a small enough cooler and plumbing it. If you can, try to find a good one with the pump bracket. That alone is $200 +.
nitepjony
Los Angeles, California
2024 Mustang GT Premium 401A
What harness and pins did you use?
Timry2
Fresno, Ca
I have the pp harness installed from factory and I took the harness apart and soldered/crimped in the missing pins. I only did mine this way if someone figures out a way to activate the OEM pump though forscan, then I'll switch it out to an OEM pump. As of now, I just installed a switch inline with the aftermarket pump to activate it. Ill attach the items as pdf's. let me know if they dont open or if you have any questions.
