Activating the factory differential cooler
FordTek
Newport News, VA
If you install the dark horse differential cooler on the mustang gt, and change the harness to the one for the differential cooler, do you have to change as-built data to activate it?
Timry2
Fresno, Ca
2024 Mustang GT, Dark gray matter, 2020 F150 XLT Sport, magnetic
Did you ever find an answer to your question.
Paul's stable
Maple Ridge BC Canada
There are some aftermarket kits. Going the DH cooler you need a new rear valance and the air diffusing panel that puts airflow thru the cooler. The aftermarket one mount the cooler different so you don't need those extra parts.
Timry2
Fresno, Ca
Yeah, I know. I pieced everything together, actually Levittown ford sells a complete kit.​
davidkwpg
Winnipeg
2025 GT 6 speed. Performance pack. Magneride. Exhaust. B & O. Stripes
I saw your signature. I had an 06 as well. Did they even offer that gear set back then? I thought the GT’s had at best 3.55’s in 2006
Paul's stable
Auto's had 3.55 gears manuals had 3.73 gears. However I put in 4.10 gears and an Eaton posi. Also it came with a 5 spd but I swapped it out for a Tremec magnum XL 6 spd. If that's your next question.
davidkwpg
Winnipeg
Actually, I was more curious as to what stage clutch you went to…did toy change that out? I had a stage one on mine and the bite point was hard and small…..not fun in traffic….was disappointed
Paul's stable
It's a duel disc McLeod unit If I remember a RXT series I think. It has been a couple of years since I had it put in. It's definitely different from stock and I don't drive it in traffic It's a garage queen only comes out on nice sunny days'.
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
I wish Ford Performance would release 4.10's for the S650 I'd swap those in a heartbeat. The difference between the 3.55 and 3.73 is substantial... I can only imagine how much more responsive the car would be with 4.10's!!!
Timry2
Fresno, Ca
Yeah, but I don’t know if there’s a way to activate the OEM diff cooler. I have the wire diagram for the diff. Cooler circuit so Im modifying the harness and building a custom passive system. I don't want to add a fan.
Paul's stable
Mine is very peppy off the line.
Paul's stable
I'm pretty sure you can get 4.10 gears for the s650 just got to go to a dependable rear end shop in your area.
