Puddle Lights how do they works? Dark Horse (EU)
MRI204
Italy
www.grena.com
MY2006 GT Roushcharged MY2020 Bullitt L2061 (sold) Q767 Dark Horse R8339
Sto confrontando i miei dati as-built con il foglio di calcolo. In realtà noto alcune cose nella sezione della luce della pozzanghera BCM 726-48-01 che penso dovrebbero essere abilitate. Dovrei, tuttavia, confrontare questi valori con un American Dark Horse 700A per essere sicuro. Poi controllerò anche il resto delle voci nelle altre sezioni! Penso che ci sia un modo per farli funzionare!
MRI204
Italy
www.grena.com
BCM 726-81-01 x*xx xxxx xx--
I have 0 on my AsBuilt data...
MRI204
Italy
www.grena.com
Anche in DDM 740-02-10 xxxx x*xx xx--
Ne ho 1.
Ma potrei provare a cambiare in 2 o 3...
Sfortunatamente, ritirerò il mio DH alla fine di settembre, quindi non potrò provarlo fino ad allora. Ma sarà sicuramente la prima cosa che proverò!
Ivan Yagüe
brazil
dark horse
My DH here in Brazil, have the pony logo and aligned when the mirror is folded. I read here in some forum that the codes:
PR3Z-13B374-C
PR3Z-13B375-B
Are from the puddle lights with the Dark Horse Logo. But how to know is it will work folded or if is the one that is aligned when unfolded?
MRI204
Italy
www.grena.com
Updates:
I finally picked up my DH last Friday and started playing with ForScan last night.
Regarding the puddle light, I managed to get it to work with the DH logo and with the same behavior as the S550. That is, when I approach the closed vehicle, the logo activates. I unlock the vehicle, and after the light show, the logo activates. When I open the door, the logo stays on. All of this requires the automatic mirror folding feature to be disabled. To get this to work, I adjusted several settings, but I think the most specific one is DDM 740-02-10 xxxx x3xx xx-- I originally had 740-02-10 xxxx x1xx xx--.
S650 Mustang Puddle Lights how do they works? Dark Horse (EU) Immagine WhatsApp 2025-11-04 ore 09.20.16_347919f1
However, I noticed that it only activates the driver's side. That is, the passenger side (right) still works as if it were original. It only activates the light when the mirror is folded, then turns off when it is opened.
Any suggestions?
Other points I changed:
BCM
726-48-01 x*xx xxxx xx-- 726-48-01 x1xx xxxx xx-- *=0 original value
726-48-02 xxx* xxxx xx-- 726-48-02 xxx0 xxxx xx-- *=0 original value
726-48-02 xxxx x*xx xx-- 726-48-02 xxxx x3xx xx-- *=2 original value
726-71-02 x*xx xxxx xx-- 726-71-02 x1xx xxxx xx-- *=0 original value
726-81-01 x*xx xxxx xx-- 726-81-01 x1xx xxxx xx-- *=0 original value
npole
Italy
Mustang Dark Horse 2024
Disabling the automatic folding mirrors is a big giveaway (for me) to have the puddles on. With the above settings you mean the lights won't stay on (although far from the door), or that settings will "auto" disable the folding mirrors as well?
MRI204
Italy
www.grena.com
I checked again, you just need to change the setting with forscan DDM 740-02-10 xxxx x3xx xx. Then you need to set the mirrors always open option from the car settings monitor. This will activate the puddle lights. But only on the driver's side for me... (I still need to check that the LED isn't burned out or the power supply polarity is reversed.)
npole
Italy
So if you don't set the mirrors to remain open, the light won't turn on? But the puddle lights in the folding mirrors cars are angled to project the light along the door, having them unfolded will project the light far from the door and at an angle.
Basic question: changing the above settings in FORSCAN and NOT disabling the folding mirrors, what will happen? The puddle lights will work as you approach the car, but when you open the door (and the mirrors will auto-unfold) the puddle lights will turn off as it happens normally?
MRI204
Italy
www.grena.com
I'll make a video….
If you don't turn off automatic folding, the lights will remain off. I also bought the lights with the DH logo for a fixed mirror.
npole
Italy
Gotcha.. then nope, I mean I won't give up to the auto folding mirrors, it's an useful feature for me.
MRI204
Italy
www.grena.com
allenouo
Australia
S650 Mustang GT
Checkout my new post, puddle lights behavior can be changed via Forscan
