here's some further details on the recall. affects 147,977 vehicles
In some of the affected vehicles, added heat-shrink caused an interference fit between the ground eyelets and sheet metal leading to distortion of the eyelets. Distorted engine wire harness grounds may break under normal vehicle vibration. A loss of ground G1D145 results in loss of motive power. A loss of ground G1D141 results in an inoperable right front headlamp, horn, windshield washer fluid pump, and air conditioning. A loss of ground G1D120 results in an inoperable left front headlamp. A loss of ground G1D143 causes an inoperable engine cooling fan, which may be accompanied by an illuminated check engine light and an audible chime.
i tried to find where these grounds are on the wiring diagrams, but it seems Ford has a different naming scheme for what's listed in the recall details vs what is numbered in the wiring diagrams
What for it… A REMEDY IS NOT YET AVAILABLE.
No S———!
Houston, we have a problem! Okay Apollo 13, stay in orbit we’ll contract you when we’re ready.
A LOSS OF MOTIVE POWER WHILE DRIVING INCREASES THE RISK OF A CRASH.
I mean that just gives a bucket load of confidence there Ford!
Quality job… they need to learn to count to four. Geeeez
about a month ago I did a small pull , WOT 0-60 and the car went into a limp mode. I made a post about it .... I'm wondering if it could be related to that. Dealer could not find anything.
Sometimes I also have issues with the USB phone cable , like static noise. It happened with two different cables.
One time also I washed the car and when I started it I got various error messages.
As long as brakes can still operate without engine power we are good. Just make sure you have strong legs lol
