How do I remove disclaimer message?
BimmerDriver
BimmerDriver
RDU, NC
BMW M3 w/3 pedals
Why do you want to disable Bluetooth in the car?
I don't want to disable BT. I want to remove the annoying message that shows when it is turned off on my phone (see original post).
BimmerDriver
BimmerDriver
RDU, NC
BMW M3 w/3 pedals
Unless you are still using one of these BT makes very little difference to battery life. I can think of no reason to not connect your phone and solve your problem in one go.
It sure seems to. I'll have to do a scientific analysis. Pixel 10.
I only spend about 2 hours a week, max, in the car. The other 166 hours, I don't need BT.
Bluetooth Low Energy (BLE) the latest version uses no power when not connected even if left on on the phone
Does Bluetooth drain battery? We ran some smartphone tests to find out
Most users won’t see any noticeable amount of extra smartphone battery drain if they forget to turn Bluetooth off.
Bluetooth drains very little of your smartphone’s battery. You really don’t need to worry.
Ok. Why do you turn Bluetooth off on your phone?
BimmerDriver
BimmerDriver
RDU, NC
BMW M3 w/3 pedals
To save the battery.
That's misleading.... it doesn't use "no power". As you yourself summarized, it uses very little. However...
I don't use the phone much. I can get 4 days from a full charge, if BT is off. I did a brief test, and in 4 hours the phone uses less than 1% of battery with BT off, but 3% with BT on. In both cases, nothing else was going on, no use. Extrapolate that to several days, and BT makes a huge difference.
Hey look - you have been given an answer to your problem which 99% of people do. If you want to argue the toss over 1% v 3% and make out it is some big deal then you are just wasting everybody's time. 🤷‍♂️
BimmerDriver
BimmerDriver
RDU, NC
BMW M3 w/3 pedals
Thank you for your time.
