GT Noise on startup and acceleration
Carter1776
Indiana
2024 Mustang GT Atlas Blue
Ok so this would be easier to explain if I had a video of it but I don’t. Anyways, when I start my GT, I get this raspy metal echo noise, like a Pringle can for headers essentially, it isn’t louder than the exhaust cold starting but it’s there enough to hear, until it idles down and then it goes away and only comes back on a new startup or mild acceleration.
I also have another noise that I’ve noticed, if you are in park and slowly rev to about 2k rpm, there is a clicking noise from under the engine, it’s not rapid or extremely consistent but it’s there and idk what it is.
i was wondering if any of you that have the GT could go out and record your car starting from under the drivers side until it idles down. This could be completely normal for these gen 4’s but I don’t know. Post the video in the replies and I’ll watch them. As well as maybe record from under the drivers side and slowly rev to 2k and see if you hear the clicking.
I’ve not had any issues at all so far and I’m at 1,080 miles on it, no dummy lights and is running fine so I’m going to assume it’s harmless but it’s one of those things that now I’ve heard it, I can’t unhear it. Thank you in advance.
LETHAL
From the D but in the NC
From the D to NC
we are going to have to hear it, but it sure sounds like the Gen III "typewriter tick". I have not heard of this on a Gen IV yet.
Carter1776
Carter1776
Indiana
I
l will get a video in the morning after work. This sounds kinda similar to what tick I hear, but again I only hear mine when I slow rev to around 2k. Probably the same thing.
I still have no idea what the muffled rasp noise I hear is though.
ThreePedalPlow
Saint Louis
And I'm pretty sure Ford changed back to a steel oil pan on the S650. Wonder if this was part of the reason. Not sure what kind of pan they were running Gen 2 and earlier though.
Carter1776
Carter1776
Indiana
If they did, it didn’t solve the tick. I’m pretty certain this is what I’m hearing tick wise.
I would still like someone to start their GT with exhaust on quiet and record with the phone right underneath the car drivers side so I can hear if they all sound how mine does.
Really difficult to diagnose without hearing. Swag, would say too many tics to terminate totally. Injectors, pulleys, cats, vibrations, etc. makes it real difficult.
the raspy at startup will be interesting. Could be anything from an open intake to a dry rub.
I’m thinking the tic from under would lean more toward exhaust and transmission or mounts than upperend drivetrain
any case, I’d keep an eye on the temps and pressures and watch for anomalies that pop up while you wait for fmc care.
ThreePedalPlow
Saint Louis
I tried to record this for you today but my phone automatically goes into Apple Car Play mode and locks out recording when I get in. I guess they don't want you driving and recording videos for safety reason. I didn't hear any clicking though. Maybe I can try again tomorrow and disconnect BT or something before I start the car tomorrow if you still need to hear something.
Carter1776
Carter1776
Indiana
I’d just like to hear what the car sounds like from a cold start to idle down from under the car, I think what I was hearing clicking wise was honestly the exhaust popping from being warm because it didn’t really happen at all today and I ran it pretty hard for a bit. For whatever reason I can’t post the video I took this morning, refuses to upload.
ThreePedalPlow
Saint Louis
Which exhaust mode are you looking for or does it not matter? Quiet, Normal, Sport or Track and where should the phone be placed precisely?
Dena
Phoenix AZ
Turn off the blue tooth on your cell phone. If you have an iPhone, you can access it on the initial screen and dragging it down. Airplane mode doesn't do it because it leaves blue tooth on.
Ford Motor Company
Official Ford Account
Dearborn, MI
Ford Mustang
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
Carter1776
Carter1776
Indiana
Quiet mode, put the phone right underneath the drivers side seat, but under the car lol. Point it at the catalytic converters.
Quiet mode and put your Phone under the car behind the driver's side front tire.
ThreePedalPlow
Saint Louis
Here it is in quiet mode. Had to compress the video to get this website to accept the file size. I didn’t mess with the audio settings at all, just the video settings like fps. This was a cold start and you can hear it idle down about 50 seconds in.
Carter1776
Carter1776
Indiana
You rock! I hear the same noise I hear on mine, it’s like the rattle/rapid tick noise and then when you hear the idle down begin it goes away. I’m going to try to compress my video and see if I can post it on here and you can listen. Makes me feel more comfortable that yours also has that.
Carter1776
Carter1776
Indiana
Mine sounds louder than yours but it was 55 degrees and the car was completely cold.
