Forscan
Dexter1924
Alabama
2024 S650 perfomance pack
I have a 2024 s650 performance pack. I know that some 10 speed s650s have hidden away the shift light indicator in the software. Is the shift light indicator only on s650 cars newer than 24? I want to activate the shift light indicator but in my research ive found that some have it and some dont.
Dexter1924
Alabama
is it possible to use Forscan with a MacBook Pro running an M1 chip?
nultyyy
Los Angeles, CA
2025 Mustang Ecoboost
To run it on MacBook you’d have to install a virtual machine of Windows on the Mac since Forscan is primarily made to run on Windows. Overall it is doable via Parallels, but it’s all kind of tedious.
(I’d recommend a windows though.
Dexter1924
Alabama
gotcha ok thank you. I am gonna have to figure out the parallels work since I only have a MacBook laptop
Dexter1924
Alabama
would it be at all possible to run this on an android device using a bluetooth obd plug
nultyyy
Los Angeles, CA
You risk bricking the module you are modifying if the connection suddenly disconnects if on Bluetooth,
You’d 99% be better off doing wired connection
SS2 GOTZ
Denver, NC
2024Mustang GT Performance Convertible
"To run it on MacBook you’d have to install a virtual machine of Windows on the Mac since Forscan is primarily made to run on Windows. Overall it is doable via Parallels, but it’s all kind of tedious."
I was able to to run it on my Macbook pro M1 using "Wine Stable" as an intermediary, googled it and found a quick and easy video, all free. I updated the speedometer display, added shift indicator, added external temp warning, and enabled walk away locks. Haven't used it in a while since several OS upgrades though. Definitely hard wire the connection for stability, lots of examples of people having problems with bluetooth connections.
