Forscan not showing continuous gear display on 2024 ecoboost
sportcolbs
Dunlqp TN
2024 ecoboost Ford mustang, 2023 Ford edge ST,2023 Raptor Ford
I have a dark horse steering wheel with working paddle shifts. When the module icon is clicked in forscan, there no continuous gear display option shown for me to enable. Any help would be appreciated. All morning has been spent trying to complete this task. And, I do have an extended paid license.
krisk
Have you tried loading it as a new vehicle when you launch Forscan instead of using the saved profile? Also, make sure if your adapter is fully seated to the OBD2 port. I’ve had missing modules when I didn’t have mine seated fully.
sportcolbs
sportcolbs
Dunlqp TN
Actually this was the first time I have used forscan on the vehicle. I had to change the Ford Performance tune back to stock to get it to read the vehicle and buy an extended license. I'll try unplugging everything and readding.
sportcolbs
sportcolbs
Dunlqp TN
I was able to find continuous gear display which was already enabled, but the vehicle does not show what gear when paddle shifting.
D/\rK•650
2025 Mustang DarkHorse
Maybe Try cycling the vehicle. Turn it off then reset the module then turn it on ect. Maybe do a soft reset from the dash and if not do a battery disconnect.
D/\rK•650
There is another member that had the same setup and he had some trouble with his but ultimately he got it working. Check the Forscan section and do a search you should find it. Goodluck
sportcolbs
sportcolbs
Dunlqp TN
Thank you, I'll see if I can find his solution.
