FORSCAN changes for Ambient Lighting?
CTX148
'24 Mustang Ecoboost
I got lucky and managed to pick up some Dark Horse door panels for my 24 base vert EB. My car didnt come with ambient lighting but the new door panels are wired for the door handle lights.
So I plugged them in and changed the APIM module using easy mode to enable ambient lighting. That part worked so I now have the buttons in the center cluster.
Im guessing I need to update a BCM/BCMB module as well? Does anyone know which module you need to change in order to get at least the door handle lights to work?
CTX148
That could very well be the case, as it turns out I wasn't able to get the lighting to work. Just in case anyone else was curious I found another issue.
I read on the 6g forum that the BCMB module controls the ALM functions. I tried to update address below:
7B7-01-01
xx*x xxxx -- (4 for ALM zone 1)
xxx* xxxx -- (2 for ALM zone 3)
However I got a configuration error when I went to write the change. My guess is the base BCMB module would need to be changed to the premium models module in order to work.
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
Would this also apply on my 301A? Or, because the 301A has MyColor, would this programming work?
I just replaced the door sills and the wiring plugs were there, however they are not recognized by MyColor or the screen nor illuminated. My Cable gets here tomorrow…
thanks in advance
thanks in advance
In y9ur case it's just finding the right line in Forscan.
Ale_star
Tampa florida
Mustang ecoboost 2024
¿Esto también se aplicaría a mi 301A? O, como el 301A tiene MyColor, ¿funcionaría esta programación?
Acabo de cambiar los umbrales de las puertas y los conectores del cableado estaban ahí, pero MyColor y la pantalla no los reconocen, ni se iluminan. Mi cable llega mañana…
gracias de antemano
[/CITA]
Hola, me gustaría saber si encontraste una manera de activar la iluminación ambiental en tu auto, ya que quiero hacer este proyecto en el mío y no sé qué línea de código reemplazar con Forscan.
