Form Lighting LED 4th Brake Light - Different Connectors
89Trooper
Central Florida
Just a heads up if you plan on ordering this mod!
2024 S650 Mustang LED Reverse Lamp | Form Lighting
I had this in my S550 and loved it... for the S650, I think it's even better how the entire assembly is changed.
I had it all installed and started to run the wires... but the connectors that go in-line are different.
Form Lighting is now aware and will be shipping me a new wiring harness. Apparently, Ford has installed different connectors in our cars, with no rhyme or reason to the trim level.
If you do order, I think you should let them know up front which connector you have to make sure you get the proper one.
Connector coming off of my taillights:
S650 Mustang Form Lighting LED 4th Brake Light - Different Connectors IMG_7493
Connector provided in the kit:
S650 Mustang Form Lighting LED 4th Brake Light - Different Connectors IMG_7495
@JakeLethal
@Diode Dynamics
Oh, you could make that fit! 😆
Thanks for the heads up! 👍
easy fix. just put a piece of aluminum wire in the pins and connect them. problem solved
89Trooper
89Trooper
Central Florida
I could cut and solder everything! Lol.
I think 7 of the 8 wires are used... so only 28 wires to do!
LawndarT
Fredericksburg VA
I’m in the same boat! Just messaged them. They look amazing, I replaced all of them. The rear reflectors were the most annoying part. If anyone has advice on reinstalling the thread cutting nuts, I’m struggling to get them to catch with a normal wrench (not a lot of room to work with)
