EDITED: help needed getting an OEM part # -- Rear Splash Shield parts
Sig Oris
Western Maine
EDIT:
If you go to the rear of the car, lie on the ground with your face facing the sky, then shimmy under the trunk area. If you look up you should see what's in the attached photo. My car is missing this and was told 60th's didn't come with it. Hope this clears things up and my Advanced English has been made some a drunk can understand.
it would appear when the dealer, four hours away, had the car undercoated, our request, the place didn’t put the rear Splash Shield back on. Its held in by several 7mm bolts, a 10mm bolt, and a couple plastic thingyies.
OK, well aware the dealer owes me the stuff but some will likely tell me that anyway which doesn’t answer my question. OH, why we bought a car four hours away is immaterial to my question.
so I’ll also need part #’s for the hardware too.
I tried google but apparently I’m not using the right name.
thanks in advance.
S650 Mustang EDITED: help needed getting an OEM part # -- Rear Splash Shield parts Screenshot 2026-05-20 at 12.49.36 PM
DarkHorsePremium
CA, Bay Area
Greetings,
Might be helpful if you took a picture of the spot with the missing piece.
I think you are referring to Mud Guards. You can look up the parts including the hardware here Shop Genuine OEM Splash Guards | Ford Parts Direct
My thought too, though they don't come on that model... maybe added some. Or he's talking about something else completely. (fender liner?)
The link you posted actually shows both, and a bunch of fasteners... That may be enough to help out the OP.
English is not my native language, but most of the time I understand very well. But this is written in some advanced English I guess. Tried to find the question but the story made me feel drunk.
Sig Oris
Sig Oris
Western Maine
see update
Sig Oris
Sig Oris
Western Maine
I suggest starting here if they are in your country
https://www.aa.org/
While the original post was perfectly completely comprehensible are we now asking for the circled part numbers (assuming the 7 and 10 mm bolts aren’t what you’re looking for) or the unidentified underbody shield (as in the rear version of the underbreath mentioned front splash shield that prevents easy access the the oil filter, that one? - i wonder if it takes roket science 🫣 - opps, here come the …..)
Sig Oris
Sig Oris
Western Maine
so I'm missing everything.
The cover, bolts, and plastic rivets.
That body shield or whatever it's called. The thingy held in place with the 7mm bolts, 10mm bolt, and plastic rivets.
Appreciate the help.
