TcarterGT2024
- Joined
- Nov 10, 2024
- Threads
- 11
- Messages
- 187
- Reaction score
- 207
- Location
- North Carolina
- Vehicle(s)
- 2024 GT 5.0 base
I’m a transmission braker. I only go into neutral just before a complete stop.
I agree, "almost" always down shift. It sounds good, saves breaks and makes driving fun, it's why I bought a standard. I typically limit downshifts to less than 4000RPM. No impact on gas usage (except RPM bump of rev match), minimal wear on car as oil flow will be high and the forces are low compared with spirited acceleration. As I tell my wife, you have to exercise the engine it keeps deposits down and keep the rings active.I typically shift down the gears when I'm coming to a stop, been doing it for years. I have not heard much about coasting to neutral written in stone on how to drive a manual to be honest, just users opinions on the matter. How do you typically drive it?
Break pads can be replaced much cheaper and easier than clutch components. Different argument; it's fun and as long as you rev-matched or close and perform the clutch engagement smoothly the forces and engine RPMs are low should be little wear.Down shifting asks the question. Do you want to replace a clutch or the brakes. Down shifting is good if your going to be in it for a while but stop signs I wouldn't do unless my brakes failed.
I’m actually floored that not everybody does this. I’ve always thought downshifting was just part of driving a manual transmission. Can’t imagine doing it any other way.I agree, "almost" always down shift. It sounds good, saves breaks and makes driving fun, it's why I bought a standard. I typically limit downshifts to less than 4000RPM. No impact on gas usage (except RPM bump of rev match), minimal wear on car as oil flow will be high and the forces are low compared with spirited acceleration. As I tell my wife, you have to exercise the engine it keeps deposits down and keep the rings active.
How does holding the clutch pedal down at red lights contribute to wear? I had a vehicle many years ago that I bought brand new, and sold with over 300,000 km on it and never replace the clutch. Over 200K km on the front brake pads. Car in gear, clutch engaged at every red light.Theres a dude who daily drives his 996 Porsche Turbo on the east coast and has racked up over 700,000 miles on it. Lots of that is in stop and go traffic. He's also tracked and autocrossed that Porsche fairly extensively.
In the lifetime of that car, he has had to replace the clutch twice. Once because the disc wore out, and once because the Transmission let go, so he may as well swap the disc out anyway.
Most people don't really want to admit it, but the clutch disk (while yes, is absolutely a wear item) can easily last what could be considered the lifetime of the vehicle so long as you don't suck at driving. Most people do suck though, they slip the clutch, hold the clutch pedal down at red lights, and don't downshift correctly.
Its honest to god a skill issue if you can't get a clutch to last at least 150K miles unless you're putting down extra power, or have an external issue, like oil on the disk or a broken finger on the pressure plate.
My old MK4 GTI reached the end of its life at 250,000 miles, and it was still on its original clutch.
My vote is for downshifting unless you have a good reason not to.
It leads to excessive wear on the throwout bearing.How does holding the clutch pedal down at red lights contribute to wear? I had a vehicle many years ago that I bought brand new, and sold with over 300,000 km on it and never replace the clutch. Over 200K km on the front brake pads. Car in gear, clutch engaged at every red light.
Interesting! I have no idea what a throwout bearing even is LOL. I'm going to research it. So what your saying is best practice after downshifting to a red light is to sit in neutral, clutch out?It leads to excessive wear on the throwout bearing.
I've seen throwout bearings overheat and wear out within 50K miles with the clutch still being fine. Bad habit that can expose flaws in an item that otherwise wouldn't have an issue.
Certainly not to say it will be a problem in every throwout bearing, but its common enough to be a consideration
Theoretically, yes.Interesting! I have no idea what a throwout bearing even is LOL. I'm going to research it. So what your saying is best practice after downshifting to a red light is to sit in neutral, clutch out?
If i’m sitting still i don’t need a gearHow does holding the clutch pedal down at red lights contribute to wear? I had a vehicle many years ago that I bought brand new, and sold with over 300,000 km on it and never replace the clutch. Over 200K km on the front brake pads. Car in gear, clutch engaged at every red light.
if i’m sitting still i don’t need a gear, since i don’t need a gear why am i holding the clutch?Fascinating! That means changing a 50-year-old practice. I was taught back in the day... never in neutral. I also ride a bike, same deal. Never in neutral. Mind you, there's more at stake on a bike if you need to take quick evasive action.
Absolutely, I put it in neutral, clutch out, at any stop if the wait is longer than a few seconds.Interesting! I have no idea what a throwout bearing even is LOL. I'm going to research it. So what your saying is best practice after downshifting to a red light is to sit in neutral, clutch out?
