89Trooper
- Joined
- Aug 19, 2014
- Threads
- 17
- Messages
- 1,239
- Reaction score
- 248
- Location
- Central Florida
- Vehicle(s)
- 2024 Mustang GT Premium
- Thread starter
- #1
Please read before answering the poll!
This always seems to be such a taboo topic when it's mentioned, and I'm curious to find out why.
Due to various things (rim width, rim offset, look, etc.) I have determined that 20mm wheel spacers will look the best all the way around, and to do this, I need to cut off 3mm from the studs. If you care about the math: our studs are 30mm long, 20mm is taken up by the spacer so 10mm needs to go into the relief hole of the rim, but my rims only have 7mm of relief, hence needing to cut off the 3mm.
Before you vote, let's look at some things:
If you vote "no", I would really love to know why you wouldn't, or why you feel it would be unsafe.
- The amount of thread engagement needed to be safe is equal to the diameter of the studs.
- Our studs are 14mm in diameter, so you need at least 14mm of thread engagement.
- Interestingly, the nuts that hold on the wheel spacers have exactly that, 14mm of thread engagement.
- Measuring with a caliper, there is at least 20mm of thread engagement using the lug nuts without wheel spacers.
