Change MPH to KPH in Forscan?
RaceRedder
Houston, TX
Dark Horse HP
Is it possible to change MPH to KPH in Forescan?
Canadian cars come with KPH programmed
USA cars come in MPH programmed
In the settings menu you can change the MPH car into KPH but you will always have MPH visible below the KPH which makes the screen look too busy.
Does anybody know if you can change the US version into the Canadian/European one in Forescan?
You’d think the computer would be smart enough to know where it’s at, especially since it can read speed limit signs.
Billycar11
Lol I wonder how that works if just sees 100kph as speed limit and it like kph mph same thing 100 mph speed limit for you if the car were in mph mode
RaceRedder
RaceRedder
Houston, TX
Dark Horse HP
No I'm not talking about speed sign recognition.
I'm talking about changing the dash from the imperial to the metric system.
And i’m saying if it can read it should be smart enough to know where it’s at, gps and all.
The car also should be smart enough to self drive and to fly.
That would make it a plane. Point being if it’s smart enough to read signs and is capable of knowing where it’s at it should be smart enough to display for the locale it finds itself in, not like they are physical gauges, it’s software.
i know im reviving a dead thread, but the solution is to go into the IPC (not into the as built data) and change the "display unit". i also recommend changing the minor gauge units. to complete the look, go into the APIM (again, not as built data), and change "country" to US for MPH or CA for KPH. what this does is changes the "Speedometer in ???" to say "KPH" with a US code or "MPH" with a CA code
SergioDiego
Bucharest
2018 Mustang EB PP
does this work? Thanks
Settings/General KPH to MPH and vise versa.
That's not the same thing as what OP wanted.
He wanted the full conversion where KPH is the main measurement.
When you do what you said, both measurements are on screen and your main country measurement is still the largest font.
