Center screen not powering down
decidave8
mobile AL
2024 mustang GT premium
Is anyone else having an issue where the infotainment screen does not power down completely? I will come back out to the car 10 minutes after I turn it off and the center screen will be glowing like it’s on with nothing displayed. If I get in and power it up and then back down, it seems to go out, but I just did that and then it came back on 10 minutes later
Loucas
Tamarac, FL
2021 Mustang GT PP Grabber Yellow
Have you tried disconnecting the battery for a few minutes and then reconnect it and see if it goes away?
Pull codes with FORSCAN if you’re able. if not, or if no codes show, record it for the dealer visit.
Alan Applegate
Roswell, NM
Hum. Mine seems to go on when I open the door. I'll have to turn off the motion detected garage light to check, as it might go on as soon as I walk up to the car?
decidave8
decidave8
mobile AL
This stays on after you walk away you can come out 10 min later and it’s lit up sometimes
Zbychersky
Poland
DH MT6 + Recaro
I have the same problem. After winter break I will visit dealer.
S650 Mustang Center screen not powering down 1000023783
decidave8
decidave8
mobile AL
That’s it. If you power on then off does it go right out?
rbeyer
2024 Mustang GT Base
I've had this happen I think twice, and I believe both of those I had left my FOB in the car (may be entirely unrelated). Cycling the accessory power got it to shut down, hopefully this gets fixed in an update.
decidave8
decidave8
mobile AL
Mine was inside my house so that does not seem to be the issue with mine
kinelisch
